Home Assistant Community
CT101 Thermostat Heating/Cooling Entities
#1
I recently installed a CT101 thermostat and ended up with 2 entities:
climate.2gig_technologies_ct101_thermostat_iris_cooling_1
climate.2gig_technologies_ct101_thermostat_iris_heating_1
It seems like I need to set the target temperature on both of those entities in order to have this thermostat work like you’d expect (change the mode to heat or cool and set a temp). If the mode is set to heat, only the _heating_1 entity actually changes the target temperature on the thermostat. If the mode is set to cool, only the _cooling_1 entity actually changes anything.
I figure if I can make a thermostat card (I’m using lovelace right now) that always changes both entities that would basically solve it.
Or maybe there’s some easier solution?
Ideas?
#2
Really the best solution would be an internal fix to HomeAssistant when the operation_mode is set to heating, control the heating entity, cooling control cooling, and make it a single entity.
#3
I agree. I might try my hand at making a custom component that uses the two entities and handles it properly.
#4
Just wanted to update this topic with a link to a solution I found that required almost no effort on my part (bonus!).
