I am running on an rpi. I deleted ALl the hassio and restarted the system. It recreated the dirctory, but when I try to to the ha commands, I get Error: Can’t start homeassistant: 500 Server Error for http+docker://localhost/v1.42/containers/92883f53bb46141824e3ba67a1b2cec9de0a99dbaf7cd71c8263e589862d81ee/start: Internal Server Error (“path /usr/share/hassio/media is mounted on / but it is not a shared or slave mount”)
I am not using an external mount, and the sytem seems able to save files etc. just never able to get homeassistant to start.
8aa1c3c47e24 ghcr.io/home-assistant/aarch64-hassio-supervisor:latest "/init" 14 minutes ago Up 14 minutes hassio_supervisor
125c5969b41c ghcr.io/home-assistant/aarch64-hassio-multicast:2022.02.0 "/init" 14 minutes ago Up 14 minutes hassio_multicast
1ad699637a2a ghcr.io/home-assistant/aarch64-hassio-observer:2021.10.0 "/init" 14 minutes ago Up 14 minutes 0.0.0.0:4357->80/tcp, :::4357->80/tcp hassio_observer
afc697908ead ghcr.io/home-assistant/aarch64-hassio-audio:2023.04.2 "/init" 15 minutes ago Up 15 minutes hassio_audio
61518e26bad4 ghcr.io/home-assistant/aarch64-hassio-dns:2022.04.1 "/init" 15 minutes ago Up 15 minutes hassio_dns
59d5df40d344 ghcr.io/home-assistant/aarch64-hassio-cli:2023.05.0 "/init" 15 minutes ago Up 15 minutes hassio_cli
