Hi
I have been at this for a few days now but cannot seem to get a response except from 401: Unauthorized
My install is pointed to a subdomain on a custom port with a valid SSL cert, browser and android app work fine on local network and outside of the home network.
The custom port is not defined in the http: section of the config and instead in the docker config maps it to the default port.
version: core-2021.12.7
installation_type: Home Assistant Container
dev: false
hassio: false
docker: true
user: root
virtualenv: false
python_version: 3.9.7
os_name: Linux
os_version: 4.4.0-157201908151420-generic
arch: x86_64
timezone: Europe/London
I am logged in as admin user and have created the Long-Lived Access Token and have followed along on the Authentication API | Home Assistant Developer Docs section and replacing the URL and user details with the correct ones but each time i get this error in the log
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:124
Integration: HTTP (documentation, issues)
First occurred: 17:15:55 (1 occurrences)
Last logged: 17:15:55
Login attempt or request with invalid authentication from my.real.ip (my.real.ip). (curl/7.68.0)
However after pasting that in i have noticed the homeassistant.components.http.ban section
Do i need to whitelist the ip?
any help would be appreciated
