My Hikvision can be controlled by using curl like this:
curl -T MotionDetection0.xml http://user:password@ip:port/MotionDetection/1
In the example above I can disable motion detection by using curl -T and the xml input file.
Can this be done in Hassio? If possible I would like to store my input xml files in a specific directory and then create restcommands for each of the functions I would like to control. Is it possible to add an input file like in the example above to the restcommand or can it be achieved using a command line switch.
Any help is appreciated!
Thanks in advance
