Hi everyone, I’m looking for some help with my current clamp sensor project that I’m struggling to get working.
I have an ESP32 board, known as the “esp32doit-devkit-v1” to esphome and is branded “esp-wroom-32”.
The current clamp sensor I have is an SCT013 100A/50mA.
For now the only code I have is for the adc platform like this:
- platform: adc
pin: A0
If I have the clamp either around no wire, around a wire with no load, or a wire with a load the adc sensor always reads 0.07500 volts.
I’m not 100% certain A0 is the correct pin as I could not find any documentation on how the pins are referred to in esphome, however, if I specify pin 34 I get NaN V instead.
I had stumbled across that page during my troubleshooting but I’m still at a loss. I presume A0 means ADC1 CH0? Below is the pin out for my exact board.
I also tried pin 3 referenced as A3, pin 32 as A4 and 34 as A6 all had similar results of a reading which doesn’t change when putting a load through the clamp.
I’m gonna go out on a limb and suggest you need to rectify, smooth, and load the output of that clamp.
I just looked at what claims to be a datasheet for it, and what I saw is a coil and a resistor. That means the signal it provides is AC, just as the only kind of current it will sense is AC.
