Current Setup: Home Assistant directly running inside of a docker container installed on a windows 10 machine.
Thoughts: Home Assistant is great and amazingly flexible. The addons for Hassio, however, look attractive as well.
Questions: Am I able to integrate all of the Hassio addons with my current setup without running/installing Hassio? If so, how would I do this? Example; The Home Assistant Control Panel is an addon for Hassio, however, I am able to access it with my current setup which does not currently include Hassio.
If not, would I be able to run/install Hassio with my current setup? If so, how? Or would I need to install Ubuntu Server in a docker container and then install Hassio there?
Thank you all in advance for any advice you are able to provide!
