Hello guys, I did this " https://github.com/digiblur/digiDryerMon" I saw on youtube with a clamp sensor, and it works perfectly, reporting Amps via MQTT. Now, is it possible to modify this yaml file to have it display Kwh instead of Amps ?
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pass
manual_ip:
static_ip: !secret ip_dryermon
gateway: !secret ip_gateway
subnet: !secret ip_subnet
dns1: !secret ip_dns1
# Enable logging
logger:
# Comment out and/or remove MQTT if you want to use the ESPHome API
mqtt:
broker: !secret mqtt_broker
username: !secret mqtt_user
password: !secret mqtt_pass
# Uncomment if you want to use the ESPHome API
#api:
ota:
web_server:
- platform: ct_clamp
sensor: adc_sensor
unit_of_measurement: "A"
icon: "mdi:flash-circle"
update_interval: 20s
filters:
- calibrate_linear:
- 0.0 -> 0.0
- 0.058 -> 7.00
on_value:
then:
- sensor.template.publish:
# codes: 0 Idle, 1 Door Open, 2 Drying
state: !lambda |-
if (x > 5) return 2;
return 0;
# if (x > 1) return 1;
internal: true
# filters:
# - debounce: 2s
on_value:
then:
- text_sensor.template.publish:
state: !lambda |-
if (x == 2) return "Drying";
return "Idle";
# if (x == 1) return "Door Open";
- platform: adc
pin: A0
text_sensor:
icon: "mdi:tumble-dryer"
