Hi All
hope somebody could help me here, i need to monitor the current flowing through a 12Vdc circuit and i have come across one of these
Is there anyway to integrate this in to a raspberry pi or utilising a esp8266/espeasy?
Hi All
What is the max current you are going to measure ?
I would like to measure up to 10A to start with but i suspect i will end up needing to measure 20A if possible.
Also would you know about monitoring the voltage 10-15V DC?
Cheers
You can take a look at this:
So as to support 20 amps you will need to change the shunt resistor but the principle is there
