I’ve got a POPP 010101 (Wireless Thermostatic Valve TRV). When I used Domoticz, I could see the current temperature, but with Home Assistant I can’t see it.
The device is already connected and I can set the temperature, but don’t the current temp.
How can I configure it?
(the device looks like the Danfoss LC13, but this one really has a temperature sensor that can report back)
I have 9 of these and everyone is showing current temp as a separate sensor.
The problem you describe has also happend to me and the trick was to include the thermostat close to the controller and then mount it on the radiator.
The device is already included, since I can control the current temperature. Do you think re-include may help?
If you included the thermostat when it was attached to the raditor and not close to the z-wave controller then I suggest you exclude it, reset the thermostat and include it again close to the controller.
After inclusion reboot Home Assistant and then mount the thermostat back on the radiator.
