Thank you.
Here is my log file.
Can you confirm that you would like me to also add my config.yaml?
2022-11-22 22:00:08.715 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration eventsensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-22 22:00:08.718 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration braviatv_psk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-22 22:00:08.719 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-22 22:00:08.721 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bmw_connected_drive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-22 22:00:08.722 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration currentcost which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-11-22 22:00:43.387 DEBUG (MainThread) [custom_components.currentcost.sensor] devices: [0, 2, 9]
2022-11-22 22:00:43.770 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->data. (See /config/configuration.yaml, line 4).
2022-11-22 22:00:51.541 ERROR (MainThread) [homeassistant.components.upnp] The 'upnp' option near /config/configuration.yaml:0 has been removed, please remove it from your configuration
2022-11-22 22:00:55.314 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Soma Connect for soma
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
OSError: [Errno 113] Host is unreachable
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.10/http/client.py", line 1282, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1328, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1277, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.10/http/client.py", line 1037, in _send_output
self.send(msg)
File "/usr/local/lib/python3.10/http/client.py", line 975, in send
self.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xa5263e80>: Failed to establish a new connection: [Errno 113] Host is unreachable
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.191', port=3000): Max retries exceeded with url: /list_devices (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xa5263e80>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 365, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/soma/__init__.py", line 58, in async_setup_entry
devices = await hass.async_add_executor_job(hass.data[DOMAIN][API].list_devices)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/api/soma_api.py", line 11, in list_devices
return requests.get(url = "http://"+self.soma_connect_ip+":"+str(self.soma_connect_port)+"/list_devices", timeout = self.timeout).json()
File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.191', port=3000): Max retries exceeded with url: /list_devices (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xa5263e80>: Failed to establish a new connection: [Errno 113] Host is unreachable'))
2022-11-22 22:01:13.622 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ state_attr("sensor.current_cost", "Temperature") | float -3 }}")
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1701, in forgiving_float_filter
return float(value)
TypeError: float() argument must be a string or a real number, not 'NoneType'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 420, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1933, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 1301, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.10/site-packages/jinja2/environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1704, in forgiving_float_filter
raise_no_default("float", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1402, in raise_no_default
raise ValueError(
ValueError: Template error: float got invalid input 'None' when rendering template '{{ state_attr("sensor.current_cost", "Temperature") | float -3 }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 536, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 422, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input 'None' when rendering template '{{ state_attr("sensor.current_cost", "Temperature") | float -3 }}' but no default was specified
