Don’t know if this is the right topic for this, correct me if I am wrong.
So… I wanted to learn some data analysis and I started to google about. There is a lot of python data science course, but with that I only learn some out of the book example. I wanted to learn by practical way, so I found this:
I decided to implement in the home assistant in the following way:
changing the arduino with an esp with tasmota firmware. This component doesn’t have to have the logic to use the scenarios
the Pi part has to be a custom component in the home assistant for logging data, and control the esp in the correct way
the cloud component is requesting the data from the home assistant through the REST API, and push back the scenarios through services
Now I need some help how to implement the custom component. I need to save the datas somewhere, but I don’t know exactly how. As I understood the scenarios has to be a class, with some attributes, and save these scenarios as a list? in order to query it later for the component, and for the REST API too. How can I do that? I found this - store the states - way, but I am not sure if it will work: Save and restore state of lights.
I have asked this question also on reddit:
Can somebody help me?
