Currently 'float' will return '0', however this template will fail to render in Home Assistant core 2021.12
whats wrong in my template?
Template warning: ‘float’ got invalid input ‘unavailable’ when rendering template ‘{% set total = states(‘sensor.growattmodbus_output_power’) | float %} {% set production = states(‘sensor.power_production’) | float * 1000 %} {% set consumption = states(‘sensor.power_consumption’) | float * 1000 %} {{ [ total - production -consumption, 0 ] | max | round(0) }}’ but no default was specified. Currently ‘float’ will return ‘0’, however this template will fail to render in Home Assistant core 2021.12
my sensor: yaml:
      solar_percent:
        value_template: "{{ ((states('sensor.growattmodbus_output_power')|float * 100) / ((states('sensor.power_consumption')|float * 1000) + states('sensor.growattmodbus_output_power')|float))|round(1) }}"
        unit_of_measurement: '%'
        friendly_name: Current Solar Percentage Realtime
In other words, what should I add/change?
See here:
Or if you’re in a hurry, replace float with float(0).
  • TemplateError(‘ZeroDivisionError: float division by zero’) while processing template ‘Template("{{ ((states(‘sensor.growattmodbus_output_power’)|float(0) * 100) / ((states(‘sensor.power_consumption’)|float(0) * 1000) + states(‘sensor.growattmodbus_output_power’)|float(0)))|round(1) }}")’ for attribute ‘_attr_native_value’ in entity ‘sensor.solar_percent’
  • TemplateError(‘ZeroDivisionError: float division by zero’) while processing template ‘Template("{{ ((states(‘sensor.pzem016modbus_w’)|float(0) * 100) / ((states(‘sensor.power_consumption’)|float(0) * 1000) + states(‘sensor.pzem016modbus_w’)|float(0)))|round(1) }}")’ for attribute ‘_attr_native_value’ in entity ‘sensor.solar_percent_pzem’
Grrrrr
You were in a hurry.
Seems ((states(‘sensor.power_consumption’)|float(0) * 1000) + states(‘sensor.growattmodbus_output_power’)|float(0))) returned 0, and dividing by 0 is not allowed.
use an availability_template so no divides by 0 happen.
How do I do that?
     solar_percent:
        value_template: "{{ ((states('sensor.growattmodbus_output_power')|float(0) * 100) / ((states('sensor.power_consumption')|float(1) * 1000) + states('sensor.growattmodbus_output_power')|float(1)))|round(1) }}"
        availability_template: "{{ ((states('sensor.power_consumption')|float(0) * 1000) + states('sensor.growattmodbus_output_power')|float(0))) != 0}}"
Why float(1) here and there?
And I get
Invalid config for [sensor.template]: invalid template (TemplateSyntaxError: unexpected ')') for dictionary value @ data['sensors']['solar_percent']['availability_template']. Got "{{ ((states('sensor.power_consumption')|float(0) * 1000) + states('sensor.growattmodbus_output_power')|float(0))) != 0}}". (See ?, line ?).
To avoid dividing by 0. the availability_template will prohibit the sensor to have an invalid value, but for now the value_template is still processed (but not used if availability is false). There is a PR to fix this.
So this error is there, but should not be? The code is correct but homeassistant is not? So I should wait to code like this and wait for an update ?
Missed a (
      solar_percent:
        availability_template: "{{ ((states('sensor.power_consumption')|float(0) * 1000) + (states('sensor.growattmodbus_output_power')|float(0))) != 0}}"
Yes, now parsing well, what’s the PR for? Will it not succeed now?
the PR is for not evaluating value_template (and not using it) when availability is false
