Curtain Card: Need help?
I need some step-by-step guidance as I do not understand the instructions to add this card:
It may be simple but how do I " The easiest way to do this is to install it in HACS as a custom repository. " ?
HACS → Frontend → icon (top right) → Custom Repositories
Paste in the repository link and select “Lovelace” as the category.
You should then be able to search for the card in HACS → Frontend if it does not immediately show up as a newly available card.
Thanks. I believe that it installed because I was asked to update to latest version, but when in Overview - Add Card there is no Curtain Card.
