Hi there,
I’ve got a automated curtain which should support Zigbee. But i won’t get it to work with Home assistant.
I already tried the following things: ZHA and Zigbee2mqtt (made a completely fresh start integrated al my zigbee devices only to find out it still doesn’t work).
The brand and type of the motor are: Model YS-MT750 manufactured by Yushun
Currently I’m back on ZHA.
I’m using this curtain motor:
This is the zigbee signature:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0051",
"in_clusters": [
"0x0000",
"0x0004",
"0x0005",
"0xef00"
"out_clusters": [
"0x000a",
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "_TZE200_r0jdjrvi",
"model": "TS0601",
"class": "zigpy.device.Device"
Is there a way to get it to work in ZHA? I’m relatively new to HA so hopefully there is a simple guide to follow to get this to work.
Hopefully someone can help.
