Good day.
I have a working Python script which controls my addressable LED strip ws2812 connected to RPi.
Two topics are used
“myhome/bathroom/led/set” with different payloads is used to control the LED (on/off, RGB and brightness)
“myhome/bathroom/led/status” send the current status in format {"color": {"r": 36, "b": 255, "g": 36}, "state": "OFF", "effect": "none", "brightness": 138}
Possible payloads to control On/off, brightness and colors are:
{"state:“ON”}, {"state:“OFF”} -to turn on/off the strip
{“state”:“ON”,“brightness”:0-255} to adjust brightness - the script will not change the brightness if the key “state”:ON is missing.
{“state”:“ON”,“color”:{“r”:0-255,“g”:0-255,“b”:0-255}} - the same as for brightness, it should contain “state”:on also.
Could anyone please advise me with the integration - how should I integrate in most proper way (end easiest as well).
light:
- platform: mqtt
schema: template
command_topic: "myhome/smartmirror/led/set"
state_topic: "myhome/smartmirror/led/status"
command_on_template: >
{"state": "ON"
{%- if brightness is defined -%}
, "brightness": {{ brightness }}
{%- endif -%}
{%- if red is defined and green is defined and blue is defined -%}
, "color": {"r":{{ red }},"g":{{ green }},"b": {{ blue }} }
{%- endif -%}}
command_off_template: '{"state": "OFF"}'
state_template: '{{ value_json.state }}'
brightness_template: '{{ value_json.brightness }}'
red_template: '{{ value_json.color[0] }}'
green_template: '{{ value_json.color[1] }}'
blue_template: '{{ value_json.color[2] }}'
optimistic: false
qos: 0
but can’t get correct state.
I am getting state in format {"color": {"r": 36, "b": 255, "g": 36}, "state": "OFF", "effect": "none", "brightness": 138}
