yes, but note it is a system wide issue, not only in this animated weather card.
And it only started when HA updated to 108.x (not sure of the version) when no update to iOS or Safari was made…
But I am using HA 108.8 and currently on IOS 13.3 it works perfectly fine, but not on 13.4. Also, it works on firefox and chrome, but not on Safari 13.1. Though i am only speaking for animated weather card, because i am not using any other animated card…
It probably is because chrome IOS is still using Safari Webkit on IOS and so is Firefox IOS. If Safari works than chrome IOS will work too automatically. And we should stop communicating same thing on both topics Let’s continue on this one…
Updated from 108.9 to 109.0 and my current temp is now near the top of the card instead of in line with the icon and name as it’s been previous to updating. Anyone else have this issue or is it just me?
Yeah I noticed this in the beta of 0.109. I modified my css entries in the card to correct it and you will need to do that for this card as well. I will post my changes in the BOM card thread in a while with my changes.
Just tried 0.109.1 on my wife’s iPhone, 12.4.5 and the icons are working so it seems it is a iOS issue.
@keithh666 if anyone wants to fix the missing gap for this version (without css knowledge) until the developer fixes it, I just added an empty markdown at the top of it to get the desired gap again:
@EMvdB It’s a custom one. It’s based on a theme I saw on reddit with a few tweaks I added.
I submitted it to HACS yesterday so it will be available there pretty soon I hope
You can add it as a custom repository in HACS in the meanwhile if you want to start using it before that: kibibit/hass-kibibit-theme
I know it was asked before but there was no answer. I would like to have more accurate readings in the card for current conditions, I have separate sensors for temperature, humidity and air pressure. Would anyone point me to the part of the config I need to edit to override these?
I’ve installed this card which also replaced the icons for another weather card (ha-card-weather-conditions) I was trying and both show animated.
The problem is that when having Lovelace on a Firefox browser on my Mac the CPU usage goes to 100%. I’ve uninstalled the card but the animated icons still remain in the other card which is strange. How do I fully disable this?
