Custom Arduino based home automation via CAN-Bus and controlled via serial port. How to read back serial port?
Hallo everybody,
I personally developed for my home several custom Arduino (ATMega328) based nodes all of them communicating via Can-Bus shields. All this is now up and running many years now.
There’s also a node that is connected to HA (running on Raspberry) via Serial Port and I already figured out a very basic way to make HA control my system. This is working like charm and I’m copy-pasting my configuration to make my work available to everybody.
What I’m missing is HA reading back constantly the serial port to detect when a state changes. And I need your help to find the best way! Or any way to do it!
Some lines from my “configuration.yaml” file:
automation:
  - alias: run_set_bedroom_light
      platform: state
      entity_id: input_number.slider_bedroom_light
      service: >
        {% if states('input_number.slider_bedroom_light') | int == 0 %}
          shell_command.set_bedroom_light_to_one
        {% elif states('input_number.slider_bedroom_light') | int == 1 %}
          shell_command.set_bedroom_light_to_two
        {% elif states('input_number.slider_bedroom_light') | int == 2 %}
          shell_command.set_bedroom_light_to_three
        {% elif states('input_number.slider_bedroom_light') | int == 3 %}
          shell_command.set_bedroom_light_to_four
        {% else %}
          shell_command.set_bedroom_light_to_five
        {% endif %}
shell_command:
  set_bedroom_light_to_one:   'echo "023001\n" > /dev/ttyS0'
  set_bedroom_light_to_two:   'echo "023002\n" > /dev/ttyS0'
  set_bedroom_light_to_three: 'echo "023003\n" > /dev/ttyS0'
  set_bedroom_light_to_four:  'echo "023004\n" > /dev/ttyS0'
  set_bedroom_light_to_five:  'echo "023005\n" > /dev/ttyS0'
switch:
  - platform: command_line
    switches:
      kitchen_light:
        friendly_name: Kitchen light
        command_on: 'echo "022002\n" > /dev/ttyS0'
        command_off: 'echo "022001\n" > /dev/ttyS0'
cover:
    covers:
      livingroom_blind:
        friendly_name: Livingroom blind
        command_open: 'echo "011002\n" > /dev/ttyS0'
        command_close: 'echo "011001\n" > /dev/ttyS0'
        command_stop: 'echo "011003\n" > /dev/ttyS0'
Explanation: home assistant sends two numbers in 6 digits: first 3 digits are the node number, second 3 digits are the new state.
Example: Node number 23 is bedroom light, the state of the light goes from 1 (off) to 5 (max intensity)
Same 6 digits are being received on tty when the state of the light changes, but I don’t know how to read it and to apply to the switch, cover, …
Looking forward to reading some suggestions! Thank you in advance!
