Before going to extreme measures (a custom component), I’d like to ask if there is a “builtin” way to achieve the target I’ll expose beloaw.
First, the existing:
- As a monitoring measure, I have command_line sensors that ssh to my various system and grab the last system error with a
dmesg -Tx -l err,crit,alert,emerg
- If the value changed (new error), I position an input_boolean, that I display on my dashboard and send notifications
- I can then take actions to solve (or ignore) the errors
- I then manually repositions the input_boolean to off to “acknowledge” that I handled the potential error.
Unfortunately, the actual error is in the state of the command_line sensor, so I have to manually check it, as I don’t display it in lovelace for cluttering reasons.
The target:
- Ideally, I would click on the input_boolean badge and see the error in its attributes. I’m pretty sure that’s not possible, as input_booleans has no custom attributes.
- The next obvious solution would be to use a template switch, but it doesn’t seem to be possible to add custom attributes to a template switch, yet, either.
The question(s):
- Is there a clever way to add custom attributes to a template switch?
- Would there be another way to achieve the target that I didn’t thought off?
