Custom attributes for unavailable devices doesn't appear
Hi everyone!
For scripting purposes, I need to add some extra attributes to some sensors. After adding them, I noticed that if the actual device is unavailable or it’s restore state set to true, custom attributes are not set.
Here’s a bunch of attributes I’ve added:
# Moode
media_player.audio_2:
  friendly_name: Ampli Bureau
  icon: mdi:speaker
  device_class: speaker
  plug: "switch.plug_9"
  delay_after_plug_on: 0
  wait_for_trigger_status: off
  turn_media_on_off: false
  delay_after_media_on: 0
  set_volume: true
  wait_for_device_after_play: true
# Caméra Salon
media_player.camera_1_yh_media_player:
  plug: "switch.plug_2"
  delay_after_plug_on: 30
  wait_for_trigger_status: idle
  set_volume: false
  wait_for_device_after_play: false
switch.plug_9:
  media_player: "media_player.audio_2"
switch.plug_2:
  media_player: "media_player.camera_1_yh_media_player"
Once HA or customization reloaded, I don’t see them, like for media_player.camera_1_yh_media_player:
But for some reason, even if media_player.audio_2 is unavailable, I can see them, which is not the case for media_player.camera_1_yh_media_player.
But I believe it has something to do with restored: true but I haven’t been able to find relevant information in the doc or the forum.
I need these information as cameras are linked to plugs, which by default are not up.
Can someone tell how to have these information even if the device is unavailable? Or I need to ass an extra parameter to set the restore attribute to false?
Thanks!
After many tests, I’m still struggling with this.
My use case for this is that I have a generic script for play TTS on all my media players (MusicCast, MPD and Yi-Hack). All these devices are plugged on smart plugs and all these devices behave differently and need specific instructions before being able to play TTS.
Thanks!
Nobody? I am totally out of ideas
Do you recall what you did to cause the media_player to get the restored: true attribute?
Thanks for your response @123.
Clearly not, I’ve never touch anything like that in my configuration.
The only difference I see between these 2 entities are their integration: the 1st one (audio_2) comes from MPD (configured via configuration.yaml) and doesn’t have any UI configuration while the other one comes from Yi Hack.
I also note a pattern for this restored: true: I have a Musicast integration (through the UI) and the behavior is similar. No custom attributes while it’s unavailable.
Still no success but I was wondering if it’s possible to add custom attributes using a service? Or something else?
As of now, the only workaround I found is to switch on plugs to get attributes populated for the entities I need. Would be great if someone had a better idea :slight_smile:
BTW @123 , can you tell what is the purpose of "restored":true?
I’ve been able to make an Restful API call to add a custom attribute but weirdly, it doesn’t work for full text-based integration like MPD while it works for Musciast:
  • Musiccast (webUI): even if the integration is set to reload itself to test if the device is up (mine is connected to a smart plug), the custom attribute survives
  • MPD (text-based): the custom attribute lives for a short moment and then disappear, probably after the integration reloads
I believe it has nothing to do with webUI/text-based integration but more with some obscure internal mechanism that I will be happy to understand so that I can use the custom attributes feature without using workarounds.
Thanks!
