Custom: Audio-Recorder-Card (connect to Rhasspy)
Hi Guys!
Today I would like to precent you to my first self-made home assistant card. Maybe someone has a use for it :wink:
You can use this card to record your voice and send a wav file via http to a server (rhasspy for example). The project has been implemented with a custom card (audio-record-card) and a custom service (recorder_service)
It’s still a beta-version, so some things will not work right. An Android and iOS support will be implemented soon.
Installation and Usage
Sorry I’m new here. So I can’t use more images and links in this post.
Support
Maybe you want to support the project :slight_smile:
Buy Me A Coffee
I cannot add recorder_service: to configuration.yaml, it says service not found
Same error. Did you find the solution?
