Custom Automation Message
I am trying to set up an automation that will let us know when any of the entry doors are opened when no one is home or if it is after sunset. I did some searching and think I have the trigger set (you can use multiple entities there can’t you?) correctly. I also wanted to capture which had been opened instead of some generic message. Again, some searching and I found reference to the {{ trigger.to_state.attributes.friendly_name }} template. However, when I run the automation, I am getting all kinds of errors and if I am reading the errors correctly, it appears to be taking exception with the trigger portion.
Anyone have any suggestions? Is there a better way to do this or do I need to list the triggers differently? It would seem like I need some kind of OR statement in the trigger, but I am not sure how to do that.
- id: OpenEntryDoor
  alias: Open Entry Door
  initial_state: 'on'
    - platform: state
      entity_id:
	    - binary_sensor.aeotec_zw112_door_window_sensor_6_sensor_3
	    - binary_sensor.aeotec_zw112_door_window_sensor_6_sensor_2
	    - binary_sensor.aeotec_zw112_door_window_sensor_6_sensor_4
      to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      entity_id: sun.sun
      state: below_horizon
    - condition: state
      entity_id: group.all_devices
      state: 'not_home'
  - service: notify.sms_a
      title: OPENED-DOOR
      message: The {{ trigger.to_state.attributes.friendly_name }} door has been opened.
  - service: notify.sms_b
      title: OPENED-DOOR
First of all, read this carefully: Important template rules
Rules 1 and 3 is for you.
Okay, so if I am understanding that correctly, then the modifications should be what I need? Can you still use the ‘title’ portion within the data template?
- id: OpenEntryDoor
  initial_state: 'on'
    - platform: state
      entity_id:
      to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      entity_id: sun.sun
    - condition: state
      state: 'not_home'
    data_template:
      title: OPENED-DOOR
      message: The '{{ trigger.to_state.attributes.friendly_name }}' door has been opened.
    data_template:
      title: OPENED-DOOR
You should quote all string, no just template:
message: "The {{ trigger.to_state.attributes.friendly_name }} door has been opened."
Don’t know about title, but I think that it would not bad.
