OK, I’m giving up on trying to figure this our on my own…
I have an Aqara motion sensor that’s connected to Zigbee2MQTT - it works flawlessly, BUT only has a 2 minute timer (I need much less). So I used this mod: https://community.smartthings.com/t/making-xiaomi-motion-sensor-a-super-motion-sensor/139806 now it actually reports motion every 5 seconds, BUT not if the motion stops under 2 minutes.
That’s why I would like to make a custom binary sensor
Zigbee2MQTT sends this mesage
zigbee2mqtt:info 6/17/2019, 8:33:06 AM MQTT publish: topic 'zigbee2mqtt/0x00158d000123456ab', payload '{"illuminance":141,"linkquality":31,"occupancy":false,"battery":100,"voltage":3065}'
An I tried to make a binary_sensor using this code:
- platform: mqtt
state_topic: "zigbee2mqtt/0x00158d000123456ab"
value_template: '{{ value_json.occupancy }}'
payload_on: "true"
off_delay: "6"
qos: 1
It does not work…
What am I doing wrong?!
petro
(Petro)
June 17, 2019, 1:34pm
2
You shouldn’t need payload on or payload off. Just set the value_template properly.
- platform: mqtt
value_template: "{{ value_json.occupancy == 'true' }}"
off_delay: 6
qos: 1
That’s if the value comes back as a string from occupancy, if it’s a boolean then you just need.
- platform: mqtt
value_template: "{{ value_json.occupancy }}"
off_delay: 6
qos: 1
I tried your suggestions, but neither one is working
petro
(Petro)
June 17, 2019, 2:14pm
4
whats not working? Also, what does the topic look like when you detect motion?
the binary sensor doesn’t report motion (but the motion sensor zigbee2mqtt creates, does detect motion)
What do you mean by that?
Is it this:
zigbee2mqtt:info 6/17/2019, 4:17:43 PM MQTT publish: topic 'zigbee2mqtt/0x00158d000123456ab', payload '{"illuminance":78,"linkquality":28,"occupancy":true,"battery":100,"voltage":3065}'
petro
(Petro)
June 17, 2019, 2:21pm
6
you have the mqtt hub set up right?
I believe so - everything else works like it should
However, I found an other solution - maybe even more elegant. It appears there’s the option to set the occupancy_timeout within Zigbee2MQTT (in share/zigbee2mqtt/configuration.yaml):
0x00158d000123456ab:
friendly_name: '0x00158d000123456ab'
retain: true
occupancy_timeout: 6 # <---
This works exactly like I wanted it to
Still, thanks for your help!
But it’s weird that this custom binary_sensor doesn’t work - I tired to use mqtt messages for other sensors before and it never worked…
petro
(Petro)
June 17, 2019, 2:36pm
8
Yeah, but the only thing that wouldn’t work is if you aren’t connecting to the mqtt ‘hub’, which is in a different section of your config. The sensor had the correct information.
Doesn’t zigbee2mqtt just send the messages over the whole network?!
I connected it with the mosquitto broker with my mqtt credentials, like everything else (sonoffs for example)
petro
(Petro)
June 17, 2019, 2:42pm
10
It does, but if you use a mqtt sensor you need to add the mqtt hub component so that the sensor has an IP to look at
isn’t the
zigbee2mqtt
part in
zigbee2mqtt/0x00device0id0123
the “address” of the hub?!
I’m a little confused now
Iike I said, I believe zigbee2mqtt is set up correctly - every sensor/lamp/switch/whatever I add, work propperly. However, I never managed to “pull” variables out of the mqtt messages for custom sensors
Well - now I feel a bit stupid, but it’s all there, in the zigbee2mqtt documentation…
I have never realized, that you could click the devices in the “supported devices” list and get to a detailed documentation on how to configure them…
petro
(Petro)
June 17, 2019, 3:48pm
13
Nope, that’s the name of the topic. The IP of your hub is wherever your mqtt broker is.
hijinx
(James)
June 17, 2019, 4:08pm
14
That got added recently I think
klim123123
(Klim123123)
September 21, 2020, 12:57am
15
i just edited \share\zigbee2mqtt\devices.yaml and added “occupancy_timeout: 6” under my aqara motion sensor. it’s just works.
you could click the devices in the “supported devices” list and get to a detailed documentation on how to configure them… but you can’t find it now… Can you post it? Thank you
