Hi Guys,
Come time when I need to have one custom button card as button, but with two actions after single tap.
Found this part of code, which works for switches and lights:
I need under one tap: one action of call service/switch off, but the second one should navigate to another tab of the dashboard. The best would be, if there could be included some few sec delay between them (but not necessary).
Can anyone point me out, how I can achieve this what I want, please?
On your button make the tap action a script. In the script add your different actions using browser_mod. I’ve done similar to make a button that turns on a device and navigates to a different dashboard.
I use this flow on tablets for a kind of temporary “dialog” box flow. There’s a button on one dash view that takes you to another “dialog” view, and when any button on this “dialog” view is pressed you’re taken back to the original view while also running the action specified with hass.callService.
The code should be self explanatory, but lmk if anything doesn’t make sense!
Edit: I’ve edited the above example to account for changes in v6 of button-card. Here’s the old example if curious, though it has been broken for some time even before v6:
This works perfect for combining a navigation and switching a toggle, Is it also possible to navigate and execute a script. I tried a few things but couldn’t get it to work. Maybe you have a solution for it?
Yes, you’re just calling an action (previously “service call”) either way. So in my example I’m calling the switch.toggle action, you’d want to call your script’s action. So it may look something like:
Hi! Modifying your script I have managed to get a button to send an mqtt message shutting down the home theater and turn on the spotlights, so the room isn’t dark. But I would like to turn on the lights to a low brightness, so we do not get totally blinded. And I can’t get the brightness working. This is the code that works:
I tried removing the end bracket after entity ID and the start bracket before brightness, but that didn’t change anything. Do you know what I’m doing wrong here? I couldn’t find anything about multi calls on the Github page for the custom button integration. I can do it by making an automation and calling that, but I would like to call directly.
[Updated] [Requires: custom:button-card installed]
I had a similar situation that the one indicated in this post, and it seems there is no built-in solution yet (github-discussion #724).
For anyone interested, I manage to have 2 actions with a single tap including the delay by using button-card’s action: custom callback, or what it seems a better way, by using action: fire-dom-event but without the delay. (no idea how to do it)
Following the suggested template from this discussion (github-discussion #986)
I added a button that when clicked triggers an script, and navigate to another tab or dashboard.
I have a couple of situations where I want a button that will control two things that can be separately controlled as well. For example, I have a button that turns on both a TV and the Sonos amplifier. So that is easy enough with multi-action, but I want to do more than that. I want the button to also turn off both items, that is, function as a toggle. I also want the same button to turn to on when the items are turned on using other controls, that is, I want it to also respond to the existing state if both are the same. I have a couple of these instances (e.g. 3 lights that can also be controlled independently). There must be a better way than the way I am doing it, because I use four separate automations. Call the two items A and B. I create an input_boolean X which the button will toggle and then my four automations are
X goes from off to on → turn A and B on
X goes from on to off → turn A and B off
A or B goes from off to on and if {A on and B on and X off} → turn X on
A or B goes from on to off and if {A off and B off and X on} → turn X off
This does produce the desired behavior, which is that X both controls and reflects independent control of the two item switches A and B. But I figure there must be a better way.
I use custom: button-cards, pretty much exclusively. I have 72 of them in my dashboard.
I think what you’re describing might be a bit different than what we’ve been discussing above.
What’s unique with what we’ve been discussing previously in this thread, is that we wanted to combine button presses with UI behavior (e.g. navigating to a different view on your dashboard), which was otherwise impossible without the button supporting it.
Yes, and in fact I use multi-actions to do exactly that, e.g. open a conditional and scroll so that conditional is at the top of the page using custom:anchor-card. This seemed like the closest existing thread to what I do in a klugy way and I was wondering if I am missing a clever way to do that.
