I am using the custom:button-card and I am trying to change the color of the icon based on the state of an input boolean. This is the code:
show_name: true
show_icon: true
type: custom:button-card
entity: input_boolean.condo_occupied
show_state: false
state:
- value: off
color: rgb(27,45,62)
- value: on
color: red
This is working just fine for the name change and the color does change based on the state. The problem is that when using the RGB function, the rendered color is always darker than anticipated.
To show this, I screenshotted a page with a default button and put it into GIMP.
The top image is the HA default off state color. I color pick it and this is what is reported:
The second button in the screenshot above then uses the RGB function using those values identical to the code snippet. As seen in the screenshot, the rendered color is darker than what was intended.
It does not matter what values I put into the RGB function, it always renders darker than intended.
If I use a built in color then it renders as the color was intended/expected.
I am not sure what I am doing wrong. Any assistance would be greatly appreciated.
