For some time I have used the integrated button-card to fire the action ihc.pulse to signal to input ressources on my IHC system.
After discovering the nice custom:button-card, I would like to use that instead. But it fails to execute the action. I have configured the button-card like this:
No reason why this should not work. While I don’t have the ihc.pulse service, everything else works and I get an error that the service does not exist.
Thanks for replying. When the ihc controller receives the pulse on the input ressource 7464977, several functions in the ihc system is started. One of the functions, toggles switch.stort_vaerelse_sydvest_3549022. And the switch is toggled correctly when using the integrated button-card , but nothing happens when the custom:button-card is used. How would you suggest debugging ?
appears identical to the original. Since I am facing the same issue, can someone point the typo out for me? BTW I am not using ihc.pulse but a different command, which works when I invoke it as a service and not when I cast it as perform-action, so this thread seems spot on.
Thank you. I see it now. Unfortunately, I was having a similar problem and the solution to this one didn’t solve mine, but AI suggested a completely different approach which worked.
