flemmingss
(Flemmingss)
October 3, 2021, 12:02pm
1
Hi.
I am working with a button.
When I tap it, it should (and it does) set the input_select.zigbee_30_lightning_effects to Slow Colorloop .
But this is what I also want: If input_select.zigbee_30_lightning_effects already is Slow Colorloop * set it to No Effect .
I guess jinja2 don’t work in this card?
type: custom:button-card
name: Slow Colorloop
color_type: card
entity: input_select.zigbee_30_lightning_effects
state:
- value: Slow Colorloop
color: yellow
icon: mdi:checkbox-blank-circle
operator: '!='
color: black
icon: mdi:checkbox-blank-circle-outline
tap_action:
action: call-service
service: input_select.select_option
service_data:
entity_id: input_select.zigbee_30_lightning_effects
option: Slow Colorloop
BONUS QUESTION: “None” as color is setting the default color, but this option is not updating “back to default”, is it another variable that set-back to default when no oher color should apply? I use “black” ass a workaround in my above code
pedolsky
(Pedolsky)
October 3, 2021, 1:44pm
2
You can template the call-service
part:
tap_action:
action: |
if (entity.state == 'Slow Colorloop') return 'none';
return 'call-service'; ]]]
service_data:
entity_id: …
option: …
This did not work.
color_type: card
state:
color: Gold
icon: mdi:pause
operator: '!='
color: DarkSlateGray
icon: mdi:play
tap_action:
action: |
service_data:
Also tried this, but it did not work:
option: |
{% if is_state('input_select.zigbee_30_lightning_effects', 'Slow Colorloop') %}
No Effect
{% else %}
Slow Colorloop
{% endif %} ]]]
pedolsky
(Pedolsky)
October 3, 2021, 3:56pm
4
Then please post the data of your input_select entity under Developer Tools → States.
options:
- No Effect
- Slow Colorloop
- Fast Colorloop
- Flashing Colors
editable: true
friendly_name: zigbee_30_lightning_effects
icon: mdi:lightbulb-group-outline
pedolsky
(Pedolsky)
October 3, 2021, 4:32pm
6
Looks like mine does. „State“ is the selected effect?
entity: input_select.hue_szenen
show_state: true
tap_action:
action: |
if (entity.state == 'Ibiza I') return 'none';
service_data:
entity_id: input_select.hue_szenen
option: Ibiza I
works like a charm, so I have no clue.
I think you might missunderstand what i am asking.
Lets say the state is “Fast Colorloop” right now.
If i select “Fast Colorloop” again now it will still be “Fast Colorloop”.
But that is not what I want.
I want it to be “No Effect” if “Fast Colorloop” is selected when it already was “Fast Colorloop”
Like: Push button again to stop the running effect.
pedolsky
(Pedolsky)
October 3, 2021, 4:58pm
8
If the colorloop effect is already running, tapping the button changes to „No Effect“:
tap_action:
action: |
if (entity.state == 'Slow Colorloop') return 'call-service';
return 'none'; ]]]
service_data:
option: No Effect
[/quote]
Depends on what „No Effect“ does (e.g. turns the light off).
“No Effect” does nothing.
I have a Node-Red flow that is constantly checking “Is state still Slow Colorloop ?” If it’s not the flow stops and the effect stops.
flemmingss
(Flemmingss)
October 3, 2021, 5:49pm
10
God it working
tap_action:
service_data:
option: |
if (entity.state == "Slow Colorloop")
return "No Effect";
else
return "Slow Colorloop";
