Hello Everyone,
I am building a remote with the picture-elements card. I have managed to set everything up. Single calls (channels with one digit only) work fine. However, when using multi-calls (for channels with 2-3 digits I am setting up for channel shortcuts), it seems the calls are being sent at the same time instead of executing calls sequentially, because digits are sent by my IR transmitter in a random order, so they work sometimes only.
I know I can do this with a script, but I’d rather not to build a single script for every channel/shortcut. I like everything to be in the same place, so please do not suggest to try the script option.
This is the interface:
And this is the code (including just one of the shortcut buttons code to make things easier):
type: picture-elements
image: local/img/Mando_Movistar.png
elements:
- type: custom:button-card
styles:
card:
- height: 40px
- width: 40px
- color: rgb(255, 0, 0, 0.0)
- background-color: rgb(0, 255, 0, 0.0)
- box-shadow: none
- border: 0px
name:
- font-size: 10px
tap_action:
action: nothing
multi-calls: |
hass.callService(
"remote",
"send_command",
{ entity_id: "remote.rm3_02", device: "movistar", command: "1" }
hass.callService(
"remote",
"send_command",
{ entity_id: "remote.rm3_02", device: "movistar", command: "2" }
hass.callService(
"remote",
"send_command",
style:
top: 34.6%
left: 83.78%
Any way to insert a short delay between every hass.callService call?
Cheers!
