I have some custom button-cards that let me toggle my RGB led strips. I would like to be able to set the current on color to the actual RGB color of the strips. I have three input numbers holding the values. Example.
input_number.kit_led_1_red
input_number.kit_led_1_grn
input_number.kit_led_1_blu
I can set the on color of the custom button card to a fixed color and it works fine. I don’t know how to create an rgb() color using input_numbers as variables. Is it possible? If so, what is wrong with my approach (see below)?
Thanks for the quick response and suggestion. Sorry, I am not very knowledgeable on how to reference values from other entities and use those values in another entity.
Unfortunately I don’t see how that will help me. I don’t need sliders, as I already have the information stored in each red , green, blue input number.
The LED lights are of type mqtt - json, if that matters.
What I need is an example of how to use those entities (input_number.kit_led_1_red, input_number.kit_led_1_grn, input_number.kit_led_1_blu) can be used in the RBG() function to set a custom color. I just don’t understand how to do that.
from the component above my automation for changing a light on the fly:
- id: dc9b5054d45444eba4b7afce05fb5f30
alias: slideColorSet
- platform: state
entity_id: input_number.slidecolor_r
- platform: state
entity_id: input_number.slidecolor_g
- platform: state
entity_id: input_number.slidecolor_b
- platform: state
entity_id: input_number.slidecolor_level
- service: light.turn_on
data_template:
entity_id: light.hallway
rgb_color:
- '{{ states.input_number.slidecolor_r.state | int }}'
- '{{ states.input_number.slidecolor_g.state | int }}'
- '{{ states.input_number.slidecolor_b.state | int }}'
brightness: '{{ states.input_number.slidecolor_level.state | int }}'
so
'rgb({{ states.input_number.kit_led_1_red.state | int }}, {{ states.input_number.kit_led_1_green.state | int }}, {{ states.input_number.kit_led_1_blue.state | int }})'
im sure there is a better way(proper, cleaner, etc) but that should get you on the right track
