Hi all, I have a driveway light which can be switched on manually or by a motion sensor. The motion sensor will activate the light for 5 minutes then switch the light off. The automation is triggered only if the light is off to avoid switching off the light when it is manually switched on.
In the dashboard I have the light in a custom button card, I want to add the timer (helper) to the same card (preferred in the background) to show how the lights are triggered and what is the remaining time.
I successfully did it through custom fields but I am unable to lay the two entities on the top of each other, only next to each other. also the card dimensions is not matching the other cards in the same grid.
