McFarTech
(Craig)
November 14, 2024, 8:26am
1
Hi Team.
I am trying to create a custom button that changes the entity picture based on the value of the sensor being 100% , 50% and less than 10%
The code below is just not showing or changing the picture. Any ideas what i am doing wrong. I have been able to change other buttons picture when its a simple on or off
type: custom:button-card
entity: sensor.group_batteries_all
show_state: false
show_name: false
show_entity_picture: true
tap_action:
action: navigate
navigation_path: /dashboard-ios/batteries
entity_picture_template: |
{% if states('sensor.group_batteries_all') | int == 100 %}
/local/img/battery-100.png
{% elif states('sensor.group_batteries_all') | int < = 50 %}
/local/img/battery-50.png
{% elif states('sensor.group_batteries_all') | int < 10 %}
/local/img/battery-10.png
{% else %}
{% endif %}
koying
(Chris B)
November 14, 2024, 8:36am
2
McFarTech:
< = 50
That’s not valid. It sshould be “<= 50”
McFarTech
(Craig)
November 14, 2024, 8:52am
3
Thanks mate for catching the typo there. i updated the code but its not made any difference the pictures displaying.
koying
(Chris B)
November 14, 2024, 9:19am
4
Keep in mind the picture will only change (or should) when the state of the group changes
McFarTech
(Craig)
November 14, 2024, 9:22am
5
The values of the entity are 100% changing and i can add and remove items from the helper group which makes the values either go up or down.
If i could get it to display a picture that would be a start
McFarTech
(Craig)
November 14, 2024, 9:44am
6
OK.
Took another look and cobbled this together. This works and displays the correct picture for the state
show_state: false
show_name: false
tap_action:
action: navigate
state:
- value: 100
operator: "=="
entity_picture: /local/img/battery-100.png
- value: 50
operator: <
entity_picture: /local/img/battery-50.png
- value: 10
operator: <
entity_picture: /local/img/battery-10.png
styles:
card:
- animation: blink 2s ease infinite
- value: 5
operator: <=
entity_picture: /local/img/battery-empty.png
koying
(Chris B)
November 14, 2024, 9:53am
7
For the record, entity_picture_template
doesn’t exist.
entity_picture
supports templates but javascript one.
Wherever you got the original code, don’t trust it anymore…
Bottom-line: Reading the documentation and using your brain make miracles
