Haha on github I have a buy me a coffee link. And my PayPal username is the same as here without the 87. But I do it to share and make everyones life a little bit better
Wow thnx! You didnt have to but its greatly appreciated!
Everyone here: Can you help come up with doable animations: Animations · Discussion #50 · marcokreeft87/room-card · GitHub
Not yet native. But if you use card mod you can. It will go on the todo list tho
just wanted to use room card. but sadly hass isn´t finding the custom card. (neither in yaml or visuell)
I tried to install with hacs and manually! All other used cards and addons are working. the room card files in ww/community also looks fine.
any off you with the some problem?
It’s a little weird, but room-card technically isn’t a card. It’s an entity. So you have to use a card that shows entities to use it. I use the entities card and then add a room-card to that. There is no GUI for room-card. It’s all YAML.
thanks for the hint kyle!
didn´t get this befor…
but i think something is not correct. I used an Entity card and then added the code from the wiki example. i think i did something wrong or?
type: entity
- type: custom:room-card
title: Attic + Garden
entity: light.alles_an
icon: mdi:lightbulb-outline
tap_action:
action: toggle
info_entities:
- entity: light.bad_eg_deckenlampe
icon: mdi:wall-sconce-flat
show_icon: true
tap_action:
action: toggle
- entity: light.terassenbeleuchtung
icon: mdi:outdoor-lamp
show_icon: true
tap_action:
action: toggle
This is where I designed it for! I love this!
Thats not right tho. It is a card. The only thing is, it doesnt have an editor because the card can do way too much to put in an editor. Maybe one day I will try to make an editor for it
Have you checked the wiki? Configuration · marcokreeft87/room-card Wiki · GitHub all the way to the bottom you can see how to use it
And also, you dont have to use the entities card for it Just use it like this
entity: light.attic
tap_action:
action: toggle
info_entities:
- entity: light.attic
show_icon: true
tap_action:
action: toggle
- entity: light.garden
show_icon: true
tap_action:
action: toggle
Thank you for all your work! Works so well and will probably integrate it for a table in our guest room soon!
Much love!
EDIT:
OH! Just realized I/we could actually use this to display all running plex transcodes and even be naughty enough to put in some transcoding switches or nice stats.
dammed. it was the “-” all the time… after removing it it worked. thanks for your work (also thanks for the wiki of course!)!
Just FYI 1.3.9 seems to have breaking changes. Either that or a regression problem. A main entity is required now even though I thought it was optional. This worked in 1.3.8:
title: Upgrade Checker
entities:
- entity: input_boolean.ecowitt2mqtt_image
state_color: true
tap_action:
action: call-service
service: input_boolean.toggle
entity_id: input_boolean.ecowitt2mqtt_image
- entity: input_boolean.iperf3_image
state_color: true
tap_action:
entity_id: input_boolean.iperf3_image
- entity: input_boolean.mariadb_image
state_color: true
tap_action:
entity_id: input_boolean.mariadb_image
- entity: input_boolean.mosquitto_image
state_color: true
tap_action:
entity_id: input_boolean.mosquitto_image
- entity: input_boolean.nextpvr_image
state_color: true
tap_action:
entity_id: input_boolean.nextpvr_image
- entity: input_boolean.phpmyadmin_image
state_color: true
tap_action:
entity_id: input_boolean.phpmyadmin_image
But now I get:
If I change it to:
show_icon: true
icon: mdi:search-web
entities:
state_color: true
tap_action:
state_color: true
tap_action:
state_color: true
tap_action:
state_color: true
tap_action:
state_color: true
tap_action:
state_color: true
tap_action:
It works again.
After latest Update i get this error. i set the show_icon attribute to true. it worked for most of the card expect 2. any idea?
That’s not supposed to be required. Thanks for telling me. A bugfix wil be available in a few hours
You have to set show_icon for each entity you define an icon for
ok thanks, problem solved.
