Ciao @alexdelprete thank you very much for everything youāre doing for this integration.
Iāve been trying to use it for my Fimer Trio 5.8 (three phases) with the VSN300 card. I was able to connect through Qmaster (ID 247, register 0). However I receive an unknown error within HA.
Looking at the logs this is what I get:
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:421
First occurred: 22:22:58 (1 occurrences)
Last logged: 22:22:58
Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 233, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 63, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 177, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 293, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 389, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/abb_powerone_pvi_sunspec/config_flow.py", line 90, in async_step_user
uid = await self.test_connection(name, host, port, slave_id, base_addr, scan_interval)
File "/config/custom_components/abb_powerone_pvi_sunspec/config_flow.py", line 65, in test_connection
self.hub_data = await self.hub.async_get_data()
File "/config/custom_components/abb_powerone_pvi_sunspec/api.py", line 187, in async_get_data
self.read_sunspec_modbus_model_160()
File "/config/custom_components/abb_powerone_pvi_sunspec/api.py", line 481, in read_sunspec_modbus_model_160
multi_mppt_id = decoder.decode_16bit_int()
File "/usr/local/lib/python3.11/site-packages/pymodbus/payload.py", line 405, in decode_16bit_int
return unpack(fstring, handle)[0]
struct.error: unpack requires a buffer of 2 bytes
Any idea what this might be? Iām running the latest version of HA on Docker (Synology NAS). Grazie in anticipo per lāaiuto!
