Unfortunately it’s not working:
2023-09-10 20:44:54.322 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 63, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 177, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 298, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 394, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/abb_powerone_pvi_sunspec/config_flow.py", line 90, in async_step_user
uid = await self.test_connection(name, host, port, slave_id, base_addr, scan_interval)
File "/config/custom_components/abb_powerone_pvi_sunspec/config_flow.py", line 65, in test_connection
self.hub_data = await self.hub.async_get_data()
File "/config/custom_components/abb_powerone_pvi_sunspec/api.py", line 133, in async_get_data
self.read_sunspec_modbus_model_1()
File "/config/custom_components/abb_powerone_pvi_sunspec/api.py", line 167, in read_sunspec_modbus_model_1
read_model_1_data.registers, byteorder=Endian.BIG
AttributeError: 'ModbusIOException' object has no attribute 'registers'
