Custom component Afvalbeheer - Support for multiple waste collectors
Is there also a next sensor? To see the next item to be collected.
And i miss a donate button…
There are 2 extra sensors for collections today and tomorrow. Add upcomingsensor: 1 to your config.
You can buy me a beer if you want. I’m still not sure if I should add the link on my repo. Feels a bit weird.
Cheers Pippyn!
You deserve it.
But they stay empty when longer then those days. Would be nice to see a icon with the next item and date that will be collected. But if not possible then it’s no problem. i’m al ready happy with this.
You can add the option dateobject: 1 to the config and then use the Home Feed Card? Does that help? Look at this issue
I will try that later. First I try to set the entity_picture.
Home assistant new for me. so i’m not that fast. :grinning:
When i set dateonly to 0, you have the days before the date, if i set it to 1 , you dont get the date but is it possible to add a third option?
I would like to have tomorrow or today without the date, but when its further away, i would be nice to have only the date…
I hope you understand me.
That’s a good idea I think.
Can you please add a feature request on the github repo?
Yes will do
Great job, version 4.1 works like a charm :+1:
Hi Paul, sorry to barge in, but where did you change this openssl setting to lower it to 1.0? I have the same problem not getting any information from the ophaalkalender website. Thx
Hi Frank, sorry for the delay. After finding out what the real culprit was, it was a bit of a search for the way to change things, but finally I found it to be quite easy. Obvious as well, because you can simply change it in the ssl config file (/etc/ssl/openssl.cnf on pi). At the very bottom of it just replace the ‘MinProtocol = TLSv1.2’ line with ‘MinProtocol = TLSv1’ then restart openssl and Bob’s your uncle … :wink:
Thx Paul, np.
Will try it out!
Did you perhaps undo the fix for ‘duobak’ in a recent release? On the latest release ‘duobak’ no longer works, but changing it to ‘papier’ again does.
Hi, this component is great!
I live in belgium and use the ophaalkalender with the postcode 3080. And can’t get my plastic trash, these are the resources I am trying to track :
resources:
- restafval
- gft
- papier
- pmd
- pbd
Is pbd the wrong one for plastics or must I indicate something else?
I’m using this for a few months now and I’m happy, it really works well. :slight_smile:
Er is wel 1 klein dingetje die ik graag opgelost zou willen zien: ik zie bij de datum de maanden nog steeds in het Engels staan. Is daar iets aan te doen?
@freakshock and @gliena
Please DM me your config so I can do some tests.
Please, English only.
It’s a know issue. I can change the code to support months also. But the current way of localization is hacky and ugly. I’m looking for a better way, but so far no luck.
Update (current version 4.2.2):
In the last few weeks there was quite some work done on this sensor. The code was almost completely rewritten/refactored. So I thought it would be a good idea to give a little update.
There is now support for the state to be a date object. This can be used with for example the Home Feed Card or the Entities Card. To do this set the option dateobject: 1. Look at this issue for more info.
It is now possible to omit the daynames form the state, but do include the “Today” or “Tomorrow” in a state. To do this set the option dayofweek: 0. Look at this issue for more info.
The new way this sensor is coded makes it quite easy to add more waste collectors. So a few waste collectors have been added. Namely:
ACV, Twente Milieu, Hellendoorn, Sudwestfryslan, RD4, De Afval App, Mijn Afvalwijzer and Ophaalkalender.be. Cure and Circulus-Berkel now use a new API and ROVA is re added.
The total list of currently supported Garbage collectors:
  • ACV
  • Afvalstoffendienstkalender
  • Alkmaar
  • AlphenAanDenRijn
  • Avalex
  • Berkelland
  • Blink
  • Circulus-Berkel
  • Cranendonck
  • Cure (use MijnAfvalwijzer)
  • Cyclus
  • DAR
  • DeAfvalApp
  • DenHaag
  • GAD
  • Hellendoorn
  • HVC
  • Meerlanden
  • MijnAfvalwijzer
  • Montfoort
  • Ophaalkalender
  • PeelEnMaas
  • Purmerend
  • RD4
  • ROVA
  • RMN
  • Spaarnelanden
  • SudwestFryslan
  • Twente Milieu
  • Venray
  • Waalre
  • ZRD
If there are any issues or feature request, please make a new issue on the github repo.
Thx @Pippyn for the update, really appreciate your efforts. I do have one question/issue.
loading
As you can see it shows that gft will be picked up tomorrow but for some reason the loading indicator keeps on going (even if I refresh 2 hours later). Any idea what is causing this or how I can help find the cause?
This a lovelace issue I think? I can’t really see what this is.
Do you have errors in your log? If so make an new issue on my github repo
