Which log file do I check for this? ha core logs or ha supervisor logs?
core logs, in the dev-tools panel
Yes the logs are normal and the component is functionaling normal.
You have a LoveLace problem then. Try displaying the sensor in another card (maybe a glance card or something)
glance card is indeed different
Is there a way to show the included icons in a color when using a glance card?
instead of black i want to use white
No sorry, maybe in the future I’ll replace the icons. For now you can use your own icons if you want?
Hi, ok no problem.
I’ll just wait then i think.
I searched for own icons, but couldnt find 3 icons with the same color, that i like
Hello, is there a support for the “afvalbeheer” for westerkwartier.afvalalert.nl? I can’t find it in this forum
Not yet, but I can look if I can find an API and implement it. Can you DM me a postcode and streetnumber? So I can do some tests?
The image below is from a post earlier. How can i add this to my dashboard?
i have tried Image entity card. But don’t know how to selcect the right image.
I tried this
type: picture-entity
entity: sensor.afval_vandaag
state_image:
'gft': /local/gft1.png.png
'papier': /local/papier1.png
'restafval': /local/restafval1.png
'plastic verpakkingsafval': /local/pmd1.png
'Geen': /local/kliko3.png
#image: 'https://demo.home-assistant.io/stub_config/bedroom.png'
aspect_ratio: 50%
but won’t work.
Am I on the right way?
check here for a current config. Garbage pickup date (mijnafvalwijzer.nl) custom_component - #429 by Mariusthvdb
there’s a typo in your config though:
take out the double .png.png…
oh thanks.
Yesterday gft was collected so maybe it worked…
Edit:
Yes it works. Thanks
I’ve installed the addon using HACS, however, I’m unsure what to use for resources.
Tilburg uses mijnafvalwijzer, but we have 2 “duobakken”. One for GFT & Restafval, and one for PMD & Papier.
This is the information for my address:
https://mijnafvalwijzer.nl/nl/5057EN/3/
If I use the settings from the example, I do get information for GFT (Maandag, 18-05-2020) but not for the others (restafval, papier, pmd)
It is unclear to me why GFT does work, and the others not.
I also tried duobak as resource, but that doesn’t give any results, and I tried “restafval & gft” and “papier & pmd” as they are mentioned like that on the website.
This is my current config (where I just added a whole bunch of resources to check what is working):
- platform: afvalbeheer
wastecollector: MijnAfvalwijzer
resources:
- papier
- pmd
- gft
- restafval
- duobak
- papier & pmd
- "papier & pmd"
- restaval & gft
- "restafval en gft"
postcode: 5057EN
streetnumber: 3
upcomingsensor: 1
dateonly: 0
dateobject: 0
nameprefix: 1
builtinicons: 0
disableicons: 0
dutch: 1
Since gft is working, I can use that for the restafval & gft duobak, but I’m missing the information for the papier & pmd duobak.
Any suggestion what I can do to add that duobak as well?
Update to version 4.2.6
Add your config something like this:
resources:
- papier-pmd
- duobak
postcode: 5057EN
streetnumber: 3
upcomingsensor: 1
dateonly: 0
dateobject: 0
nameprefix: 1
builtinicons: 0
disableicons: 0
dutch: 1
Restart HA
Great, that works!
Thanks a lot!
I installed HA, installed HACS, added afvalbeheer, edited configuration.yaml.
Getting this error: Platform error sensor.Afvalbeheer - Integration ‘Afvalbeheer’ not found.
First time user, so probably I am doing something wrong
after you added afvalbeheer and before you edited the config you need to restart HA. HACS will notice you to do so.
You can comment out (or cut) the config for the sensor. Restart HA.
Re-add the config and restart again.
thanks, that worked!
streetnumber = housenumber?
get an unknown state
your config for Limburg.NET should look something like this (no postcode needed):
wastecollector: Limburg.net
resources:
- restafval
- gft
- papier
- pmd
cityname: Heusden-Zolder
streetname: Schootstraat
streetnumber: 1
