Custom component AIMP Media Player
hi,
I’m trying create AIMP integration with this:
using modified code from mphc and volumio component, but the code dont work
can someone point where i miss something,
    def send_aimp_msg(self, method, params=None):
        """Send message."""
        try:
            data = {"version": "1.1", "method": method, "id": "1", "params": params}
            requests.post(f"http://{self._url}/RPC_JSON", data=data, timeout=3)
        except requests.exceptions.RequestException:
            _LOGGER.error(
                "Could not send command %s to AIMP at: %s", method, self._url
    def update(self):
        """Update state."""
        try:
            playinfo = self.send_aimp_msg("GetPlaylistEntryInfo", params="{playlist_id: -1, track_id: -1}")
            self._playinfo = playinfo.copy()
            control = self.send_aimp_msg("SubscribeOnAIMPStateUpdateEvent", params="{event: \"control_panel_state_change\"}")
            self._control = control.copy()
            coverurl = self.send_aimp_msg("GetCover", params="{playlist_id: -1, track_id: -1, cover_width: 512, cover_height: 512}")
            self._coverurl = coverurl.copy()
and here is the log
aimp: Error on device update!
  File "/config/custom_components/aimp/media_player.py", line 109, in update
AttributeError: 'NoneType' object has no attribute 'copy'
[UPDATE]
You can download AIMP custom component for Home Assistant on link below:
[CASE CLOSED]
apparently my code didn’t work because no response from AIMP.
after add firewall exception and got response from AIMP,
few trial and error, my code works now… yay
only select source/playlist haven’t work yet, but other function works well
Could you please share your code template. I want to create same player.
im sorry for late answer
you can check yaml config and AIMP custom component on my github
i just updated the custom component today, it broken on latest HA but it works now after fix breaking changes
feel free to ask again if there are something not clear
