0.18.0
Better backend
2023-01-21
Features
- Updated backend
asusrouterlibrary and communication with Asus API:- minimized number of API requests
- updated obtaining of connected devices data
- updated LED features
- updated communication with all the used API endpoints
- Added secondary WAN info (feature request #464)
- Added access point mode of operation (feature request #C397)
- Removed deprecated fields and simplified configuration flow
Bug fixes
- Fixed bug with beta FW versions (report #467)
- Removed
restart_firewallbutton from AiMesh node mode of operation (a node cannot control firewall in any case, so the entity was useless)
Translations
- Updated French translation (@novisys)
Documentation
- Updated compatible devices list
Dependencies
- Migrated to
asusrouterlibrary0.18.0,0.18.1,0.18.2,0.18.3 - Migrated to
asusrouterlibrary0.19.0,0.19.1
0.18.1
Better FW handling and more
2023-01-22
Features
- Improved parsing of FW versions
Bug fixes
- Fixed bug with VPN switches (report #C414)
- Fixed bug with handling errors on API requests for WLAN and GWLAN data
Dependencies
β 0.18.1 on GitHub β
Support AsusRouter
Monetary support:
- You can make a donation using the Buy Me a Coffee service
- Thinking of buying a new Asus router to use with AsusRouter integration? Check the compatibility list in our Docs. If you will use any of the Amazon Associate links, I might get a small (1-3%) bonus from Amazon (usage of the associate links does not change the price of the items for you)
Non-monetary support:
- Star AsusRouter repository
- Know a person with an Asus device using Home Assistant but not AsusRouter? Let them know, AsusRouter is cool and has lots of useful features
New firmware support
Maybe you have already seen it, but some of the newer devices have recent beta FW versions starting with 9.0.0.6. In this case, 9 just means beta, but the more important part is switching from 4 to 6. Not like Asus did it ever before, so some parts of the API might become completely different - who knows?
My goal will be to support all the possible devices and FWs but in case of large changes that will take some time. Also, rumours are not on the side of older devices (including my RT-AX88U), so I am not sure when I will get a chance to try these new versions in real life.
Want AsusRouter to become a native part of Home Assistant?
Vote for the feature request on this forum. More votes - more chances to be accepted into HA Core
Not an announcement anymore
@spry-salt, might be, that something was not cached properly. In any case, I am glad, everything works fine for you now.
@majorsl, @dr3as, please, check the new access_point mode and let me know what do you think and whether it should be improved more.
P.S. to everyone. If I have forgotten to answer your message here on the forum, just remind me - itβs completely fine. From time to time I might postpone replying and then forget. Sorry in such a case ![]()
