I don’t have lots of statistics, but my 2 HA instances are actually working in exactly the same way in Hyper-V VMs of a PC and all 3 show up. But from time to time one of them might disappear for some period of time. I’ll try to watch their behaviour to find if there is something I can improve in tracking them
Thank you. Taking a guess here, the MAC address of the HA VM starts with 00. None of the other devices do. The HA VM is the only one that doesn’t show in the list in the integration. Maybe the leading 00 is a cause?
Well I’ve tried a number of things now. The ASUS client list shows all connected devices, but the HA ASUS integration shows all of them except the homeassistant server. Maybe ASUS or merlin made a change in the latest firmware that’s excluding certain entries for some reason.
EDIT: So I removed the homeassistant server from the DHCP list on the router, then set the server to use a static address, then restarted the router… now the ASUS client list doesn’t show the homeassistant server at all. So maybe that had been cached before and kept being displayed on the router client list, but the integration was receiving a more updated list? Who knows.
Thinking of buying a new Asus router to use with AsusRouter integration? Check the compatibility list in our Docs. If you will use any of the Amazon Associate links, I might get a small (1-3%) bonus from Amazon (usage of the associate links does not change the price of the items for you)
Know a person with an Asus device using Home Assistant but not AsusRouter? Let them know, AsusRouter is cool and has lots of useful features
New firmware support
Maybe you have already seen it, but some of the newer devices have recent beta FW versions starting with 9.0.0.6. In this case, 9 just means beta, but the more important part is switching from 4 to 6. Not like Asus did it ever before, so some parts of the API might become completely different - who knows?
My goal will be to support all the possible devices and FWs but in case of large changes that will take some time. Also, rumours are not on the side of older devices (including my RT-AX88U), so I am not sure when I will get a chance to try these new versions in real life.
Want AsusRouter to become a native part of Home Assistant?
Vote for the feature request on this forum. More votes - more chances to be accepted into HA Core
Not an announcement anymore
@spry-salt, might be, that something was not cached properly. In any case, I am glad, everything works fine for you now.
@majorsl, @dr3as, please, check the new access_point mode and let me know what do you think and whether it should be improved more.
P.S. to everyone. If I have forgotten to answer your message here on the forum, just remind me - it’s completely fine. From time to time I might postpone replying and then forget. Sorry in such a case
Thanks for your work, it’s such a cool integration. Just ran into an error with the latest though, trying to switch on or off a vpn client:
2023-01-22 18:29:34.539 ERROR (MainThread) [custom_components.asusrouter.switch] Switch control has returned an exception: ('Something went wrong running service `stop_vpnclient1`.Raw result is: {}', None)
Do I need to change anything for that switch to work in the updated version please?
0.18.1 is out with several bug fixes and the full release log is up there.
@spry-salt, please check it, when you will have a possibility
By the way, are there any users of the new RT-AX88U Pro, TUF Gaming AX6000 or others? Curious if someone has the new beta 9.0.0.6 builds on their devices to check their work with AsusRouter
Hello all. Thanks for putting together this component. I’m looking for a little help using this component in a Node-Red flow. I’d like to block internet access to a specific device. I beleive I would use the call service node with the device_internet_access service. I would then put the entity ID (the device to block) and the block access command in the data field. Can someone help me with the JSON syntax for this? Appreciate the help.
I don’t know if it’s related, But Yesterday i got the “same” message for various “entities” during a “re-setup” of “Tuya Local” ( there it said, no longer provided by Tuya-Local ), where i have my wifi-switches, i was about to get frustrated because the devices where indeed there, and visible in router, and working in mobile-app , i rebooted etc. etc. and those i had re-integrated in “Tuya Local” were greyed-out (not working) on and off, totally crazy evening.
How ever the Tracker-entities were all there during that, and working fine as usual … which got me to the conclusion that it might not be latest AsusR update, but maybe latest Core update … anyway 3-4 reboot during yesterday eve, i eventually got All wifi switches reinstall in “Tuya-Local”, and the switches working again.( not greyed out )
@automateitall, I will check with Node-Red flows and publish something on using AsusRouter services a bit later today
@poudenes, please, try reloading AsusRouter using the Reload button on the integrations page
It might be, that the result will be different from just rebooting all the HA - don’t ask why - it just happens. In general, the restart_firewall entity should become active again. If not, please open an issue on GitHub.
Actually, you don’t need to remove and set up the integration. If everything works as expected, the entity will just appear again after restarting integration / HA
