If, you mean me , everything is fine here, was my point
0.21.1
Support for HA 2023.3.x
2023-02-24
ā
GitHub change log ā
Features
- Added support for HA 2023.3.x
Dependencies
- Bumped
asusrouter
library to0.20.3
Support AsusRouter
Monetary support:
- You can make a donation using the Buy Me a Coffee service
- Thinking of buying a new Asus router to use with AsusRouter integration? Check the compatibility list in our Docs. If you will use any of the Amazon Associate links, I might get a small (1-3%) bonus from Amazon (usage of the associate links does not change the price of the items for you)
Non-monetary support:
- Star AsusRouter repository
- Know a person with an Asus device using Home Assistant but not AsusRouter? Let them know, AsusRouter is cool and has lots of useful features
106 votes
Installed the update. now Iāve got 3 integrations
The log says:
Platform asusrouter does not generate unique IDs
Did 2 additional duplicates appear by themself after the update? Or was the device discovered (even though already set up) and you added it again?
In the last case, please just delete the duplicates.
The issue with the discovery of the already set up device is not yet fixed and requires some time to fix. Meanwhile, you can just āignoreā it using the Ignote button in HA - it wonāt appear again
Yes like that. I will remove them
Hi @Vaskivskyi
Could you consider adding Reboot DDNS client button as a feature request please.
Many thanks
Hello, @neeu2,
If this can be done from Web UI, it should be possible to implement it into the integration.
How do you perform DDNS restart from Web UI? So it would be easier for me to find all the needed info.
Is it possible that this integration would slow down router in any way? I experienced occasionally that my router became slow, unresponsive when i tried to enter routerās config page and iāve had to reboot it eventuallyā¦
Now i run HA without asus integration for a couple of weeks now and router is stable so far, but i canāt just tell yetā¦ iād have to reinstall addon and see if becomes slow again.
When iāve had addon installed iāve had all sensors āincludedā, maybe there were too many trafficā¦?
I run rt-ax88U as main router, then 2x RT-AC86U and 1x RP-AX56 as AiMesh points ( first two are connected wired, last one is connected wirelessly to main router).
Doing via Web UI involves Clicking āNoā to āEnable the DDNS clientā and then āApplyā and then clicking āYesā to the same setting and āApplyā the setting (Under Advanced Settings>WAN>DDNS). Please see the image below. I normally use SSH and then run āservice restart_ddnsā
@neeu2, @Protoncek, great. Thanks for the tips! Iāll check it out. Should not be too hard, probably
@Protoncek, hey. The integration works with the device the same way, as Web UI does and connects using the same method. It can slowly increase RAM usage (to keep the session live) but should be cleaned properly by the device and free the RAM by itself.
Do you accidentally have Merlin 388.1 on your RT-AX88U? This is something I am experiencing with my one - from time to time it stops responding to new SSL sessions (e.g. if you want to login into Web UI), but at the same time all the other sessions are kept live well. Also, you can access via non-SSL session. Unfortunately, this is something FW-related and does not happen on stock or just in older versions.
Edit: in my case, this is a self-fixed thing. Everything recovers in a couple of minutes without any useful info in the log
Yes, i do run 388.1 fw. So, itās fwās faultā¦ ok, good to know, in this case letās hope that next one will fix that. Thanks!
Hi, I just upgraded. Iām also using latest merlin fw and after upgrading and rebooting HA had the device (AX11000) rediscovered. I havenāt configured/added the newly discovered device yet as I was confused, so came here and saw this thread.
Should I āignoreā the new device (3 dot menu), or delete the original one and setup the newly discovered one?
Thanks!
Hello. A new version will be available in the following couple of days, which should solve the issue with rediscovered devices. Until that time, you can ignore the rediscovered device
Hello all,
Iām new to HA and on a steep learning curve with all the cards, especially the cards in the cards etc. Best way of learning is figuring out someone elseās making. So, if you have created an awesome dashboard, please share it here with the code, to help me to learn dashboard/card creation. That would be much appreciated!
@Vaskivskyi what an awesome job you did, and as far as I can make from the documentation and the information you share and your support on this forum, a very professional awesome job. Thank you very much.
Please search the Forum for this, there are lots of exam ples, for / with card-code, view code etc. etc. , AND itās nothing you should ārequestā under this, or other Component specific Topics, these specific Topics are made for the component, releases, troubleshooting etc
Thanks for your reply.
I did and tried all 4 of them that had code, with different outcome.
Iām still interested in other examples.
Great work!!
I have linked various Asus Router device tracker to various Person entities and it is working great wrt. identifying is someone is being home.
But having problems when I try to use Person directly to plan my morning commute route as it lacks the GPS location when sourced by the Asus device tracker and have to work around by changing quite configure redirect my automations and scripts from the Person entities to various mobile app device tracker entities.
Is it possible to add GPS location using an user configurable default home GPS location for all stationary tracker for this type of use case in the future?
GPS is not something routers deal with, at least not that Iāve ever heard. The router has no way to know GPS coordinates of devices connected to it. GPS is not part of LAN networking protocols. All it can really provide is if a device connects/disconnects to the network and identify it by the devices MAC address. The app is different because it can send any data (including GPS coordinates) via whatever network connection is established, back to another app/server that reads and uses it.
Weāre way off topic here (sorry) but just use your Home location as your start point and plan your commute from thereā¦your home lat/long is already setup in HA (most likely) so just use this as part of your setupā¦so if this Integration shows you at home then calc commute from home lat/long to your destinationā¦
Now back to Integration only talk
