Thx for the info.
I checked this is simillar to what I would like to do.
I rewite my program, but is the same
I am using more sensor (8) then its only updateing 2 the rest is time out. ( the get request is time out )
import asyncio
from datetime import timedelta
import logging
import aiohttp
import async_timeout
import voluptuous as vol
import sys
from homeassistant.exceptions import PlatformNotReady
from datetime import datetime
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import ATTR_ATTRIBUTION, CONF_NAME
from homeassistant.helpers.aiohttp_client import async_get_clientsession
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.entity import Entity
_LOGGER = logging.getLogger(__name__)
BKK_URI="https://futar.bkk.hu/api/query/v1/ws/otp/api/where/arrivals-and-departures-for-stop.json?key=apaiary-test&version=3&appVersion=apiary-1.0&onlyDepartures=true&stopId={stopId}&minutesAfter={minutesAfter}"
SCAN_INTERVAL = timedelta(seconds = 120)
REQUEST_TIMEOUT = 10
CONF_ATTRIBUTES = ("Information provided by: https://futar.bkk.hu/")
CONF_STOPID = 'stopId'
CONF_MINSAFTER = 'minsAfter'
CONF_WHEELCHAIR = 'wheelchair'
CONF_BIKES = 'bikes'
CONF_IGNORENOW = 'ignoreNow'
DEFAULT_NAME = 'BKK Futar'
DEFAULT_ICON = 'mdi:bus'
DEFAULT_UNIT = 'min'
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_STOPID): cv.string,
vol.Optional(CONF_MINSAFTER, default=20): cv.string,
vol.Optional(CONF_WHEELCHAIR, default=False): cv.boolean,
vol.Optional(CONF_BIKES, default=False): cv.boolean,
vol.Optional(CONF_IGNORENOW, default='false'): cv.boolean,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
_LOGGER.debug("[" + sys._getframe().f_code.co_name + "]--> %s", config.get(CONF_NAME))
name = config.get(CONF_NAME)
stopid = config.get(CONF_STOPID)
minsafter = config.get(CONF_MINSAFTER)
wheelchair = config.get(CONF_WHEELCHAIR)
bikes = config.get(CONF_BIKES)
ignorenow = config.get(CONF_IGNORENOW)
#api_sensor = BKKPublicTransportSensor(name, stopid, minsafter, wheelchair, bikes, ignorenow)
#async_add_entities([api_sensor], update_before_add=False)
dev = []
api = CallAPI(async_get_clientsession(hass), hass.loop, name, stopid, minsafter)
#data = await api.get_json()
#_LOGGER.debug("[" + sys._getframe().f_code.co_name + "] %s", data)
dev.append(BKKPublicTransportSensor(api, name, stopid, minsafter, wheelchair, bikes, ignorenow))
async_add_entities(dev, True)
class myRequestError(Exception):
"""Error to indicate a API request has failed."""
pass
class BKKPublicTransportSensor(Entity):
"""BKKPublicTransportSensor API Sensor."""
def __init__(self, api, name, stopid, minsafter, wheelchair, bikes, ignorenow):
"""Initialize the sensor."""
self._api = api
self._name = name
self._stopid = stopid
self._minsafter = minsafter
self._wheelchair = wheelchair
self._bikes = bikes
self._ignorenow = ignorenow
self._state = None
self._attributes = {}
async def async_update(self):
"""Update station state."""
try:
_LOGGER.debug("[" + sys._getframe().f_code.co_name + "]--> %s", self.name)
# Init before new query
json_response = await self._api.get_json()
if json_response["status"] == "OK" and len(json_response["data"]["entry"]["stopTimes"]) > 0:
bkkdata = json_response
attr = {}
attr["stationName"] = bkkdata["data"]["references"]["stops"][self._stopid]["name"]
attr["items"] = len(bkkdata["data"]["entry"]["stopTimes"])
failedNode = 0
if attr["items"] != 0:
currenttime = int(bkkdata["currentTime"] / 1000)
i = 0
while i < len(bkkdata["data"]["entry"]["stopTimes"]) - failedNode:
if 'departureTime' not in bkkdata["data"]["entry"]["stopTimes"][i + failedNode]:
failedNode += 1
continue
diff = 0
diff = int((bkkdata["data"]["entry"]["stopTimes"][i + failedNode]["departureTime"] - currenttime) / 60)
if diff < 0:
diff = 0
if self._ignorenow and diff == 0:
failedNode += 1
continue
attr['in' + str(i)] = diff
tripid = bkkdata["data"]["entry"]["stopTimes"][i + failedNode]["tripId"]
routeid = bkkdata["data"]["references"]["trips"][tripid]["routeId"]
attr['type' + str(i)] = bkkdata["data"]["references"]["routes"][routeid]["type"]
attr['routeid' + str(i)] = bkkdata["data"]["references"]["routes"][routeid]["iconDisplayText"]
attr['headsign' + str(i)] = bkkdata["data"]["entry"]["stopTimes"][i + failedNode]["stopHeadsign"]
if self._wheelchair:
if 'wheelchairAccessible' in bkkdata["data"]["references"]["trips"][tripid]:
attr['wheelchair' + str(i)] = str(
bkkdata["data"]["references"]["trips"][tripid]["wheelchairAccessible"])
if self._bikes:
if 'bikesAllowed' in bkkdata["data"]["references"]["trips"][tripid]:
attr['bikesallowed' + str(i)] = bkkdata["data"]["references"]["trips"][tripid]["bikesAllowed"]
i += 1
attr["items"] = len(bkkdata["data"]["entry"]["stopTimes"]) - failedNode
self._attributes = attr
self._state = "[" + datetime.now().strftime("%H:%M") + "] " + str(self._minsafter)
if 'in0' in self._attributes.keys():
self._state = "[" + datetime.now().strftime("%H:%M") + "] " + str(self._attributes['in0'])
#_LOGGER.debug("async_updatex: %s", self._state)
#return self._state
except ValueError:
_LOGGER.error("[" + sys._getframe().f_code.co_name + "] Received non-JSON data from API endpoint")
except vol.Invalid as err:
_LOGGER.error("[" + sys._getframe().f_code.co_name + "] Received unexpected JSON from " " API endpoint: %s", err)
except Exception as e:
_LOGGER.error("[" + sys._getframe().f_code.co_name + "] Exception: " + str(e))
@property
def device_state_attributes(self):
"""Return the state attributes."""
#_LOGGER.debug("[" + sys._getframe().f_code.co_name + "]--> %s", self.name)
#_LOGGER.debug("device_state_attributes: " + self._attributes)
if self._attributes:
return self._attributes
return {ATTR_ATTRIBUTION: CONF_ATTRIBUTES}
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def state(self):
"""Return the state of the sensor."""
#_LOGGER.debug("[" + sys._getframe().f_code.co_name + "]--> %s %s", self.name, self._state)
return self._state
@property
def icon(self):
"""Return the icon."""
return DEFAULT_ICON
@property
def unit_of_measurement(self):
return DEFAULT_UNIT
class CallAPI:
"""Call API."""
def __init__(self, session, loop, name, stopid, minsafter):
"""Initialize."""
self.name = name
self.session = session
self.loop = loop
self.stopid = stopid
self.minsafter = minsafter
async def get_json(self):
"""Get json from API endpoint."""
value = None
url = BKK_URI.format(stopId=self.stopid, minutesAfter=self.minsafter)
try:
async with async_timeout.timeout(REQUEST_TIMEOUT, loop=self.loop):
response = await self.session.get(url)
value = await response.json()
except Exception:
pass
_LOGGER.debug("[" + sys._getframe().f_code.co_name + "]<-- ready %s", self.name)
return value
