I have a custom component that I built for HA for a basic IP-enabled relay/switch board. As the board is very basic, it only has the capability to do GETs for updates.
To integrate this with HA, I created an apache reverse proxy that injected a long-lived access token header. This reverse proxy is a Docker container:
<VirtualHost *:8443>
ProxyRequests On
ProxyPreserveHost On
ProxyPass / http://192.168.2.10:8123/
ProxyPassReverse / http://192.168.2.10:8123/
Header add Authorization "Bearer LONGLIVEDTOKEN"
RequestHeader set Authorization "Bearer LONGLIVEDTOKEN"
ServerName localhost
</VirtualHost>
I also have the following in HA:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.22.0.100. #IP address of apache reverse proxy
With @frenck’s PR #38696, my component is now broken. I’m assuming I was not strict enough on the X-Forwarded header. I have tried to debug, but am getting nowhere. Can anyone offer any insight?
cheers,
J.
