Correct. The code is here https://github.com/nagyrobi/home-assistant-custom-components-cover-rf-time-based
In case you’re interested, I made (yet another) fork of the project:
- Covers can be configured via
config_flow
(web-ui) in Helpers section, no need to deal with YAML code. - Added event listening to the switches, manually turning on the
switch
will also update/sync thecover
position in Home Assistant
Kudos @davidramosweb for the base code!
Thanks! I have some doubts in the way to create the helpers…but I will keep trying.
Hi David, is it possible to check the set position method? For me is not working correctly. If I set position from 100 to 90 it continues till 0…
I have a cover entity and no switches.Can I use this to close and open?
Is your Sonoff RF bridge modified? I have my R2.2 bridge flashed with esphome (but no portisch firmware nor direct hacked). When I send raw command nothing happens (orange light usually flashes but not when sending raw)
button:
on_press:
then:
- rf_bridge.send_raw:
raw: 'AAB04A0314026C010E1374F0011001101010010110100101010101100101100101011010011001101001011010101010101010011010101010101010101010100110010101011010010110100255'
Is there a way to convert this raw code to “sync, low, high, code” format that the bridge usually sends?
