Hello @jokkydee!
Thanks a lot for your time and effort on your reply!
About the pinout I must say that first I tested all the pins with a multimeter, and on my panel I have, only one GND pin, with 0 volts, one pin with 13 V and all the rest measured 5 volts. So initially I put my UART working on 5 volts… no luck! Changed it to 3,3 V … no luck! Considering that…I even tried reversing the TX with the RX on the pinout, but no luck either! (with 5 V and 3,3 V)
As you said I could have a software version problem, but honestly I doubt it, I’m using the same version that I saw on a youtube video of someone that was configuring a panel like mine with the D-LINK cable and the software Runner (https://www.youtube.com/watch?v=YBVjSBuL5lk).
One thing that caught my attention on the video was the fact that software Runner has a CD led (maybe a representation for the presence of an extra needed CARRIER DETECT pin on the interface) always lit on the Window screen…
Could there be any problem on the COM port configurations selected on the Windows operating system?
Bits per second: 9600
Data bits: 8
Parity: None
Stop bits: 1
Flow Control: Hardware
Anyway, I even tried changing the Bits per second (9600, 19200, 38400, 115200), the Flow control (None, Hardware) but no connection was established…
Are there any specific configurations I should use for the UART CP201X that I bought on Windows (by the way I’m using Windows 11)? Or the default options, as shown above, are the correct choice? (specially about FLOW CONTROL which one must be the option selected?)
Here is a screenshot of the software I’m using (I always do “Run as Administrator” when starting the software as the youtube video mentioned):
One thing that seemed strange to me, is that whatever option I change on the COM port setting on Windows, the information that I coloured GREEN on the screenshot above never changes… it does not indicate anything about FLOW CONTROL, but…are those the supposed right options for the port configuration settings? I guess so…but…maybe not…
The software version is wrong? I don’t know…but for a Crow Runner 8/16 panel I did not find another version to download on the Internet…
Suggestions? Any? I really appreciate…
Thanks in advance!
