Custom component development, loading python dependencies
I’m trying to support the development of a custom component, but for some reason I fail to handle Python dependencies. They are in manifest.json, are installed but I still see No module named 'xcomfort' and encounter a failure.
manifest.json looks like this:
  "domain": "xcomfort_bridge",
  "name": "Eaton xComfort Bridge",
  "version": "0.1.2",
  "config_flow": true,
  "documentation": "https://github.com/jankrib/ha-xcomfort-bridge",
  "issue_tracker": "https://github.com/jankrib/ha-xcomfort-bridge/issues",
  "requirements": [
    "xcomfort==0.1.2",
    "rx==3.0.1",
    "pycryptodome==3.15.0"
  "system_packages": true,
  "ssdp": [],
  "zeroconf": [],
  "homekit": {},
  "dependencies": [],
  "codeowners": [
    "@jankrib"
Using: ghcr.io/home-assistant/home-assistant:latest, I can see that they are installed to /config/deps when I try to add the component.
Debug logs:
2024-11-09 07:58:10.887 INFO (SyncWorker_50) [homeassistant.util.package] Attempting install of xcomfort==0.1.2
2024-11-09 07:58:10.888 DEBUG (SyncWorker_50) [homeassistant.util.package] Running uv pip command: args=['/usr/local/bin/python3', '-m', 'uv', 'pip', 'install', '--quiet', 'xcomfort==0.1.2', '--index-strategy', 'unsafe-first-match', '--upgrade', '--constraint', '/usr/src/homeassistant/homeassistant/package_constraints.txt', '--target', '/config/deps']
2024-11-09 07:58:12.317 INFO (SyncWorker_50) [homeassistant.util.package] Attempting install of rx==3.0.1
2024-11-09 07:58:12.317 DEBUG (SyncWorker_50) [homeassistant.util.package] Running uv pip command: args=['/usr/local/bin/python3', '-m', 'uv', 'pip', 'install', '--quiet', 'rx==3.0.1', '--index-strategy', 'unsafe-first-match', '--upgrade', '--constraint', '/usr/src/homeassistant/homeassistant/package_constraints.txt', '--target', '/config/deps']
2024-11-09 07:58:12.631 INFO (SyncWorker_50) [homeassistant.util.package] Attempting install of pycryptodome==3.15.0
2024-11-09 07:58:12.631 DEBUG (SyncWorker_50) [homeassistant.util.package] Running uv pip command: args=['/usr/local/bin/python3', '-m', 'uv', 'pip', 'install', '--quiet', 'pycryptodome==3.15.0', '--index-strategy', 'unsafe-first-match', '--upgrade', '--constraint', '/usr/src/homeassistant/homeassistant/package_constraints.txt', '--target', '/config/deps']
2024-11-09 07:58:13.114 DEBUG (MainThread) [homeassistant.loader] Importing platforms for xcomfort_bridge executor=['config_flow'] loop=[] took 0.00s
2024-11-09 07:58:13.115 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration xcomfort_bridge: No module named 'xcomfort'
I can see that xcomfort is installed in /config/deps, but not loaded. So I expect it’s not in $PYTHONPATH.
ls custom_components/ deps/
custom_components/:
xcomfort_bridge
deps/:
aiohappyeyeballs                  attrs                       multidict-6.1.0.dist-info      Rx-3.0.1.dist-info
aiohappyeyeballs-2.4.3.dist-info  attrs-24.2.0.dist-info      multidict.libs                 xcomfort
aiohttp                           Crypto                      propcache                      xcomfort-0.1.2.dist-info
aiohttp-3.10.10.dist-info         frozenlist                  propcache-0.2.0.dist-info      yarl
aiohttp.libs                      frozenlist-1.5.0.dist-info  propcache.libs                 yarl-1.17.1.dist-info
aiosignal                         idna                        pycryptodome-3.15.0.dist-info  yarl.libs
aiosignal-1.3.1.dist-info         idna-3.10.dist-info         pycryptodome.libs
attr                              multidict                   rx
I’ve added a logging statement in the custom component __init__.py to confirm and found that indeed /deps/config is not in the Python path.
2024-11-09 08:55:13.136 INFO (ImportExecutor_0) [custom_components.xcomfort_bridge] Python path: ['/config/deps/lib/python3.12/site-packages', '/config', '/usr/local/lib/python312.zip', '/usr/local/lib/python3.12', '/usr/local/lib/python3.12/lib-dynload', '/usr/local/lib/python3.12/site-packages', '__editable__.homeassistant-2024.11.1.finder.__path_hook__']
Not sure how this should work for custom components, any guidance would be appreciated here.
Seems to be related to: Integrations that require a Python module installation fail to add on 2024.10.1 when installed through HACS · Issue #127966 · home-assistant/core · GitHub
