I’m creating custom component that depend on external library. The library is mentioned in the manifest of the component and is installed into the deps
folder.
If I try it locally with virtual environment it works properly, but if I try to install the component using hacs into the home assistant runing in the cluster, it can not find the module: ModuleNotFoundError: No module named 'pyamasicp'
, even if the module is in the deps
folder.
