Custom Component: Dreame Vacuum
You need to disable Cleaning Sequence setting if you want vacuum to follow the order that you passed.
Thanks for the quick reply! Itā€™s up and running now.
As for the misunderstanding about the dreame cloud support, I basically just chose the worst possible path of implementationā€¦. Setup the vacuum with Dreamehome app before doing any research. Then researched here briefly and saw a bunch of old posts about requiring the Mi Home app. Switched the robot to that app, struggled, and then posted here after a bunch of troubleshooting.
Thanks for getting the Dreame cloud integration working! That is a huge step for these vacuums, and I imagine it will be a much easier path for most folks.
I did notice one anomaly during the 2.0.0b6 installation. There are two check boxes at the bottom of the configuration page that donā€™t have any text next to them. Once installed, the configuration page shows what they do.
Great find, I will fix that, thanks.
The user/pass authentication boxes during installation arenā€™t labeled either
Which language is set in HA?
Language in HA is English
HA Version?
It was 2023.10.2 at the time I installed the integration.
Hi, Would you update the supported devices?
I got dreame.vacuum.r2232c (DreameBot L10s Prime), but itā€™s not on list.
I could not find other way to let this device get into HA with all features.
Can you add support to STYJ02YM? @tasshack . My friend has the Xiaomi Mop S10 ijai.vacuum.v17 and cant get to work either.
Those two devices are not made by Dreame and has nothing common with the Dreame devices therefore cannot be used with this integration.
Will be added on the next beta release.
I find the projects very interesting. Is it also possible to access the live images of the robot? for example of an L10s Ultra?
I have problems with using automation for low_water_warning ā€¦ how to set it up, please? it only shows ā€œavailableā€ or ā€œnot availableā€ , which is the same if the integration has not correctly loaded or there is a wifi problem :confused:
thank you
Thanks, worked
Hi, I have a problem with my map on Dreame D9. After few weeks/months from mapping, map crashes. Until now, I could restore first map without any problems, but now I got error message ā€œOperation failedā€. Could I use Yourā€™s integration to restore first map somehow?
Or could I download somehow first map, factory reset vacuum, and upload this map?
Whats the vacuum card you would suggest closest to dreame app layout to use with this integration?
Hi. Wanna buy X30 Pro. But doesnā€™t on the supported list. Is this already supported or will be in the future?
