Custom Component: Dreame Vacuum
Obstacle images (different from manually taken saved photos) will be available on the next beta release but camera stream will not for a while.
Been running beta 2. For a while now. Very stable and steady. No issues so far :slight_smile:
Same here, on Beta and everything ok.
I think it’s time to promote from beta to stable.
Thank you and best regards.
I am wondering if this can work for a machine bought from china . I can still add it to mi home but it will said region locked when i try to use it. Can I use this to make my s10 work again? Thanks
You cannot use this integration for bypassing the region lock if the device has a firmware version that blocks commands when country is unmatched.
thanks, for your information.
any news about integratin DREAME D10S plus?
I have a dreame.vacuum.r2210. On app in cell works fine but in HA get this erro:
I tryed local and cloud
Logger: homeassistant.config_entries
Source: config_entries.py:402
First occurred: 5:22:07 PM (1 occurrences)
Last logged: 5:22:07 PM
Error setting up entry rose for dreame_vacuum
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 402, in async_setup
result = await component.async_setup_entry(hass, self)
File “/config/custom_components/dreame_vacuum/init.py”, line 22, in async_setup_entry
coordinator = DreameVacuumDataUpdateCoordinator(hass, entry=entry)
File “/config/custom_components/dreame_vacuum/coordinator.py”, line 125, in init
persistent_notification.EVENT_PERSISTENT_NOTIFICATIONS_UPDATED,
AttributeError: module ‘homeassistant.components.persistent_notification’ has no attribute ‘EVENT_PERSISTENT_NOTIFICATIONS_UPDATED’
I am a little bit confused…
where can I reenter my login data?
Edit:
solved the problem, I updated to the Beta
Sorry for the delay. What should I do to share with you?
Hi, i have a xiaomi s10+ . I add the custom component and seems to work correctly. The only thing Is the select zone or area . I can select but when i Press the start button It does not work.
On the bottom of the homeassistant Page i have the message call of service vacuum_to_go or vacuum_clean_zon failed.
Can i do something?
Can you please add xiaomi C101(xiaomi mijia self cleaning robot mop 2) model?
Hi, I’ve just brought an L20 Ultra and set it up using the DreameHome App. When I try to set it up on Home Assistant it’s not accepting my user ID and Passowrd that I use for the app. Is it because the creadentials it’s looking for are for the Mi Home app?
Make sure you’ve installed the beta version of this integration
It is not a Dreame device therefore cannot be supported by this integration.
Hey @tasshack your work is impressive. I’m also interested in the integration of the DREAME D10S plus. Just bought one. Is it planned for the next time? Please give @pitiriguisvi and me an hopeful answer.
Perfict, thank you.
Already available in Beta.
Ok. Thank you!
Stable fix for HA 2023.11+ has been released.
