I just Made a United States version of EcoFlow Cloud Custom Integration
[](https://github.com/snell-evan-itt/hassio-ecoflow-cloud-US/releases)
[](https://hacs.xyz) [](https://community.home-assistant.io/t/custom-component-ecoflow-cloud-api-for-us-users/799962)
# EcoFlow Cloud Integration for Home Assistant
Inspired by [hassio-ecoflow](https://github.com/vwt12eh8/hassio-ecoflow) and [ecoflow-mqtt-prometheus-exporter](https://github.com/berezhinskiy/ecoflow-mqtt-prometheus-exporter) this integration uses EcoFlow MQTT Broker `mqtt.ecoflow.com` to monitor and control the device.
## Installation
[](https://my.home-assistant.io/redirect/hacs_repository/?category=integration&repository=hassio-ecoflow-cloud-US&owner=snell-evan-itt)
- Install as a custom repository via HACS
- Manually download and extract to the custom_components directory
Once installed, use Add Integration -> Ecoflow Cloud.
## Disclaimers
⚠️ Originally developed for personal use without a goal to cover all available device attributes
This file has been truncated. show original
HA-one
January 7, 2025, 4:59pm
2
Thanks for adding to the Ecoflow ecosystem.
Do you know of any tutorials on how to obtain the necessary information so new Ecoflow devices can be added? I just purchased a River 3.
akasianchuk
(Kasianchuk Andrii)
December 11, 2025, 7:21am
3
Thank you for this great integration. It helps me a lot.
Do you know what is the best way to understand the device is offline? As All sensors keeps showing a static value if the device goes offline.
Thank you.
akasianchuk
(Kasianchuk Andrii)
December 30, 2025, 10:21am
4
I’ve solved it using another integration (Ping) which just pings the device by IP. For this I’ve assigned a static IP for the Ecoflow and it seems to work as I need.
Thanks again for this great integration.
