Epic Games Custom Integration Home Assistant
Custom integration for the Home Assistant to obtain information present in epicgames.com.
Install
Installation via HACS
Have HACS installed, this will allow you to update easily.
Adding Epic Games to HACS can be using this button:
If the button above doesn’t work, add https://github.com/hudsonbrendon/ha_epic_games
as a custom repository of type Integration in HACS.
- Click Install on the
Epic Games
integration. - Restart the Home Assistant.
Manual installation
- Copy
epic_games
folder from latest release to your<config dir>/custom_components/
directory. - Restart the Home Assistant.
Configuration
Adding Epic Games to your Home Assistant instance can be done via the UI using this button:
Manual Configuration
If the button above doesn’t work, you can also perform the following steps manually:
- Navigate to your Home Assistant instance.
- In the sidebar, click Settings.
- From the Setup menu, select: Devices & Services.
- In the lower right corner, click the Add integration button.
- In the list, search and select
Epic Games
. - Follow the on-screen instructions to complete the setup.
Debugging
To enable debug for Epic Games integration, add following to your configuration.yaml
logger:
default: info
logs:
custom_components.epic_games: debug
Make a card
To view Epic Games information, follow an example of a card. Remember to install the upcoming-media-card
type: custom:upcoming-media-card
entity: sensor.epic_games
title: Epic Games
max: 10
image_style: fanart
date: ddmm
line1_text: "Metacritic: $rating"
After setup, the card above will look like this:
