Custom Component - ESXi Stats
It is good to know you can do this on the free licence, I cannot call the service “esxi_stats.vm_power”, and see the following error thrown in the logs.
2020-05-02 20:55:04 INFO (MainThread) [homeassistant.components.script] vm_action: Running script
2020-05-02 20:55:04 INFO (MainThread) [homeassistant.components.script] vm_action: Executing step call service
2020-05-02 20:55:04 ERROR (MainThread) [homeassistant.components.script] vm_action: Error executing script. Service not found for call_service at pos 1: Unable to find service esxi_stats/vm_power
2020-05-02 20:56:07 INFO (MainThread) [homeassistant.components.script] vm_action: Running script
2020-05-02 20:56:07 INFO (MainThread) [homeassistant.components.script] vm_action: Executing step call service
2020-05-02 20:56:07 ERROR (MainThread) [homeassistant.components.script] vm_action: Error executing script. Service not found for call_service at pos 1: Unable to find service esxi_stats/vm_power
Would appreciate any help on diagnosing this, thanks in advance.
Just checking the GitHub, apparently you do need “a full ESXi licence” I presumed that this means paid, and that the free licence is not compatible to unlock the API?
Fabio, how? I put all esx integration entities on exclude list, but it did not helped :frowning:
Ho to put component on the exclusion list?
Can I shutdown and restart the host with this integration or only the VMs?
Wow!
Could you share your configuration?
Thanks!
The warning message comes from homeassistant.core, so if you want to suppress I/O messages you would need to set homeassistant.core logging level to error or higher. However, keep in mind, this will hide all of the warnings, not just those related to I/O blocking from esxi _stats.
At the moment only VM power can be controlled via services. Host controls can be added, create a feature request.
Thanks WTX9861… this is what I was affraid after reading recorder documentation…
For the sake of other possible errors I’ll leave it unfiltered for the time being.
This setting helps:
i have it like:
logger:
  default: warning
  logs:
    homeassistant.util.async: fatal
That works too but I don’t want to restart HA to do that :stuck_out_tongue:
Getting a ton of errors in my logs since upgrading HA 0.109.x. I believe they’ve changed something fundamental that is now spamming my log with errors.
2020-05-18 23:17:47 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/__init__.py, line 259: vm_name = vm.summary.config.name.replace(" ", "_").lower()
2020-05-18 23:17:47 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 173: vm_conf = vm.configStatus
2020-05-18 23:17:47 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 174: vm_sum = vm.summary
2020-05-18 23:17:47 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 175: vm_run = vm.runtime
2020-05-18 23:17:47 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 176: vm_snap = vm.snapshot
I started using this decluttering template instead of the horseshoe card one:
decluttering_templates:
  vm_entity_template:
    card:
      type: entities
      title: '[[name]]'
      entities:
        - entity: '[[entity]]'
          type: attribute
          attribute: state
          icon: 'mdi:server'
          type: attribute
          attribute: guest_os
          icon: 'mdi:server'
          type: attribute
          attribute: guest_ip
          icon: 'mdi:ip'
          type: attribute
          attribute: cpu_count
          icon: 'mdi:cpu-64-bit'
          suffix: cores
          type: attribute
          attribute: used_space_gb
          icon: 'mdi:harddisk'
          suffix: GB
          type: attribute
          attribute: memory_allocated_mb
          name: RAM Allocated
          icon: 'mdi:memory'
          suffix: MB
          type: attribute
          attribute: uptime_hours
          icon: 'mdi:history'
          suffix: hours
          type: attribute
          attribute: snapshots
          icon: 'mdi:camera'
        - type: 'custom:bar-card'
          entity_row: true
          entities:
              attribute: cpu_use_pct
              unit_of_measurement: '%'
              decimal: '0'
              min: '0'
              max: '100'
              height: 30px
              severity:
                - color: var(--label-badge-green)
                  to: '40'
                - color: orange
                  to: '65'
                - color: var(--label-badge-red)
                  to: '100'
          style: |-
            bar-card-name {
              font-weight: bold;
              text-shadow: 2px 2px 2px black;
            bar-card-value {
              font-weight: bold;
              animation:
                state: 'on'
          entity_row: true
          entities:
              attribute: memory_used_mb
              unit_of_measurement: MB
              decimal: '0'
              min: '0'
              max: '[[max_memory]]'
              icon: 'mdi:memory'
              height: 30px
          style: |-
            bar-card-name {
              font-weight: bold;
            bar-card-value {
              font-weight: bold;
              animation:
                state: 'on'
Card:
template: vm_entity_template
type: 'custom:decluttering-card'
variables:
  - entity: sensor.esxi_vm_pfsense
  - name: pfSense
  - max_memory: 3072
I’m getting this error since I updated to version 0.110.2
## Log Details (WARNING)
Logger: homeassistant.util.async_
Source: util/async_.py:120
First occurred: 12:04:27 AM (57 occurrences)
Last logged: 12:04:27 AM
* Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 173: vm_conf = vm.configStatus
* Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 174: vm_sum = vm.summary
* Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 175: vm_run = vm.runtime
* Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 176: vm_snap = vm.snapshot
* Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for esxi_stats doing I/O at custom_components/esxi_stats/esxi.py, line 31: current_session = conn.content.sessionManager.currentSession.key
It is known.
edit - solved. The problem below was due to my rookie yaml mistakes. Once I cleaned up the syntax, all worked fine. Using a real editor was a huge help in finding indentation errors.
I’ve installed ESXi Stats and its working great. Trying to set up the horseshoe card based on the examples found at https://github.com/wxt9861/esxi_stats/tree/master/examples has been a challenge. No matter what changes I make, the result is a blank screen. The flex-horseshoe-card and de-cluttering card have been installed via HACS and the corresponding .js files are in the www/community folder. I’ve tried referencing the url path under resources with a path of “url: /community_plugin/” as well as “url: /hacsfiles” both without success.
I know it is probably something simple or I’m missing a basic concept but at this point, I am out of ideas. I’d appreciate any suggestions anyone might have. If this post should be put somewhere else, please let me know.
thanks in advance
ui-lovelace.yaml file
resources:
  - url: /community_plugin/flex-horseshoe-card/flex-horseshoe-card.js
    type: module
  - url: /community_plugin/decluttering-card/decluttering-card.js
    type: module
  !include decluttering_card_templates.yaml
  title: Test
  cards:
    - type: custom:decluttering-card
      template: vm_flex_template
      variables:
        - entity: sensor.sensor.esxi_vm_win10_homeserver
        - name: 'HomeServer'
  vm_flex_template:
    card:
      type: 'custom:flex-horseshoe-card'
      entities:
          decimals: 2
          unit: '%'
          area: CPU
          decimals: 0
          unit: 'H'
          unit: 'MB'
          decimals: 0
          unit: 'GB'
          unit: ' '
          attribute: status
      show:
        horseshoe_style: 'lineargradient'
        scale_tickmarks: true
      card_filter: card--dropshadow-none
      layout:
        hlines:
          - id: 0
            xpos: 50
            ypos: 38
            length: 70
            styles:
              - opacity: 0.2;
              - stroke-width: 4;
              - stroke-linecap: round;
        vlines:
          - id: 0
            xpos: 50
            ypos: 58
            length: 38
            styles:
              - opacity: 0.2;
              - stroke-width: 5;
        states:
          - id: 0
            entity_index: 0
            xpos: 50
            ypos: 30
            styles:
              - font-size: 2.6em;
              - opacity: 0.9;
          - id: 1
            entity_index: 1
            xpos: 46
            ypos: 54
            styles:
              - font-size: 1.6em;
              - text-anchor: end;
          - id: 2
            entity_index: 2
            xpos: 54
            ypos: 54
            styles:
              - font-size: 1.6em;
              - text-anchor: start;
          - id: 3
            entity_index: 3
            xpos: 54
            ypos: 74
            styles:
              - font-size: 1.6em;
          - id: 4
            entity_index: 4
            xpos: 46
            ypos: 74
            styles:
              - font-size: 1.6em;
              - text-anchor: end;
        names:
          - id: 0
            xpos: 50
            ypos: 100
            entity_index: 0
            styles:
              - font-size: 1.3em;
              - opacity: 0.7;
              - opacity: 0.7;
          - id: 1
            xpos: 46
            ypos: 60
            entity_index: 1
            styles:
              - font-size: 0.8em;
              - text-anchor: end;
              - opacity: 0.6;
          - id: 2
            entity_index: 2
            xpos: 54
            ypos: 60
            styles:
              - font-size: 0.8em;
              - opacity: 0.6;
          - id: 3
            xpos: 54
            ypos: 80
            entity_index: 3
            styles:
              - font-size: 0.8em;
              - opacity: 0.6;
          - id: 4
            xpos: 46
            ypos: 80
            entity_index: 4
            styles:
              - font-size: 0.8em;
              - text-anchor: end;
              - opacity: 0.6;
        areas:
          - id: 0
            entity_index: 0
            xpos: 50
            ypos: 15
            styles:
              - font-size: 0.8em;
      horseshoe_state:
        color:  '#FFF6E3'
      horseshoe_scale:
        min: 0
        max: 100
        width: 3
      color_stops:
        05: '#FFF6E3'
        15: '#FFE9B9'
        25: '#FFDA8A'
        35: '#FFCB5B'
        45: '#FFBF37'
        55: '#ffb414'
        65: '#FFAD12'
        75: '#FFA40E'
        85: '#FF9C0B'
        95: '#FF8C06'
thanks
Funny you posted this, I posted something similar for this integration using decluttering cards and button cards.
In case anyone is interested…
I feel like I am missing something very stupid simple. I have the integration going, but I am only getting 2 Datastores, 1 License, 4 VMs, and 1 Ethernet as entities. What I want to get are those 8 entities, but I also want CPU, RAM, etc entities for each of the VMs individually. Is this possible? What am I missing?
Got this resolved. Anyone looking for another example of splitting the up:
#PLEX SENSORS
    sensors:
      plex_vm_state:
        friendly_name: "Plex State"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','state') }}"
    sensors:
      plex_vm_uptime_hours:
        friendly_name: "Plex Uptime (Hours)"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','uptime_hours') }}"
    sensors:
      plex_vm_uptime_days:
        friendly_name: "Plex Uptime (Days)"
        value_template: "{{ states('sensor.plex_vm_uptime_hours')|int /24|round(1) }}"
    sensors:
      plex_vm_cpu_count:
        friendly_name: "Plex CPU Count"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','cpu_count') }}"
    sensors:
      plex_vm_cpu_use_pct:
        friendly_name: "Plex CPU Used (%)"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','cpu_use_pct') }}"
    sensors:
      plex_vm_memory_allocated_mb:
        friendly_name: "Plex Memory Allocated (MB)"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','memory_allocated_mb') }}"
    sensors:
      plex_vm_memory_used_mb:
        friendly_name: "Plex Memory Used (MB)"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','memory_used_mb') }}"
    sensors:
      plex_vm_used_space_gb:
        friendly_name: "Plex Used Space (GB)"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','used_space_gb') }}"
    sensors:
      plex_vm_tools_status:
        friendly_name: "Plex Tools Status"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','tools_status') }}"
    sensors:
      plex_vm_guest_ip:
        friendly_name: "Plex Guest IP"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','guest_ip') }}"
    sensors:
      plex_vm_snapshots:
        friendly_name: "Plex Snapshots"
        value_template: "{{ state_attr('sensor.esxi_vm_plex','snapshots') }}"
    sensors:
      plex_vm_memory_used_pct:
        friendly_name: "Plex Memory Used (%)"
        value_template: "{{ states('sensor.plex_vm_memory_allocated_mb')|int / states('sensor.plex_vm_memory_used_mb')|int *100|round(1) }}"
    sensors:
      plex_vm_used_space_pct:
        friendly_name: "Plex Storage Used (%)"
        value_template: "{{102400 / states('sensor.plex_vm_used_space_gb')|int /10.24|round(1) }}"
@wxt9861
Anyone running into issues pulling the “memory used mb” field? Mine is showing at about 99% used, but looking at ESXi directly, it should be reading at something like 8% used.
